Factory Reset Second Hand Catalyst 3560-X Series 48 POE (with C3KX-NM-10G Modules)
Hi all,
We recently acquired some 2nd hand Catalyst 3560-X Series 48 POE (with C3KX-NM-10G Modules) but the previous owner did not wipe their configurations.
Following this similar community post - https://community.cisco.com/t5/other-network-architecture/urgent-password-recovery-with-the-3650/td-p/2629200
When holding down the reset switch during boot it takes us to the password-recovery mechanism
Next
switch: flash_init
Then
switch: switch_ignore_startup_cfg=1
Then
switch: boot flash_packages.conf
However the message then displays
Loading "flash_packages.conf"...flash_packages.conf: no such device
Error loading "flash_packages.conf"
Interrupt within 5 seconds to aboard boot process.
Boot Process failed
Running dir shows the file systems as
bs[0]: (read-only)
flash[6]: (read-write)
xmodem[7]: (read-only)
null[8]: (read-write)
Any assistance would be greatly appreciated.
Hello
To wipe the 3560 would be based on its password recovery sequence but instead if renaming the config.text file in the flash you just delete it and then boot the iOS up which isn’t packages.conf if I am correct but a bin file
rommon:
Dir flash:
delete flash:config.text
boot
once rebooted
Copy running-config startup config
Kind Regards
Paul
