Is N9K-X9788TC-FX compatible with N9K-C9508-FM-E?
sschubert
Hi, I'm trying to find out definitively if the above card is compatible with the N9K-C9508-FM-E Fabric modules. When I do the configuration in CCW, the N9K-X9788TC-FX is the only 1/10GBaseT module option in CCW and the data sheet says it's compatible. However, the installation documentation says the N9K-X9788TC-EX is what is compatible. I'm guessing the install documentation is incorrect but I would like to verify that the -FX is the module I need.
Data Sheet https://www.cisco.com/c/en/us/products/collateral/switches/nexus-9000-series-switches/datasheet-c78-736677.html?cachemode=refresh
Install Guide https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/hw/n9508_hig/guide/b_n9508_nxos-mode_hardware_install_guide/b_n9508_hardware_install_guide_chapter_01010.html
Thanks, Steve
0 Replies 0
