Local SPAN on Nexus 9k with filter access-group not working
Difan_Zhao
Hi experts, I have C93180YC-FX running NXOS 9.2(2). Here is my SPAN config. I am not receiving anything. I have a Ubuntu box doing the capture with tcpdump. It only has 1G port on the server so I have to do filtering to limit the amount of traffic being SPAN'ed.
interface Ethernet1/18
  switchport
  switchport mode trunk
  switchport monitor
  no snmp trap link-status
  no shutdown
ip access-list nmsprd010
  10 permit ip 10.9.58.90/32 52.112.0.0/14
  20 permit ip 52.112.0.0/14 10.9.58.90/32
monitor session 3
  filter access-group nmsprd010
  source interface port-channel29 rx
  source interface Ethernet1/22 rx
  destination interface Ethernet1/18
  no shut
Once I remove the filter, I would see packets pouring in.
I read in the Nexus 9K guide that "An access-group filter in a SPAN session must be configured as vlan-accessmap". What does it mean? It sounds vague to me... Does it mean that I have to use VLAN as the source? Anyway, I tried but still got no packets. I would see packets as soon as I remove the filter..
monitor session 3
  source vlan 1023 rx
  no shut
I never SPAN'ed a VLAN before. Does it require the switch to have a VLAN interface to SPAN on the Layer 3 level? My switch is layer 2. Can it SPAN on all Layer 2 ports in this VLAN 1023?
Thanks!
Difan
Sergiu.Daniluk
Hi @Difan_Zhao
"vlan-accessmap" is what the name suggests - an VLAN ACL, or looking at the command, a "vlan access-map".
In the SPAN configuration guide, there is an example how to configure ACLs with SPAN:
switch# configure terminal
switch(config)# ip access-list match_11_pkts
switch(config-acl)# permit ip 11.0.0.0 0.255.255.255 any
switch(config-acl)# exit
switch(config)# ip access-list match_12_pkts
switch(config-acl)# permit ip 12.0.0.0 0.255.255.255 any
switch(config)# vlan access-map span_filter 5
switch(config-access-map)# match ip address match_11_pkts
switch(config-access-map)# action forward
switch(config-access-map)# exit
switch(config)# vlan access-map span_filter 10
switch(config-access-map)# match ip address match_12_pkts
switch(config)# monitor session 1
switch(config-erspan-src)# filter access_group span_filter
In your case,since vlan access-map "nmsprd010" does not exists, the SPAN is blocked. Try configuring one similar with the exhibit above and let us know of the results.
Stay safe,
Sergiu
Sergiu.Daniluk
Hi @Difan_Zhao
Stay safe,
Sergiu
Thanks, Sergiu! Sorry, I never heard of the VLAN access-map lol I assumed it was a typo. My bad!
Now I see the packets but somehow I see duplicates... It shouldn't be the real duplicates by the source/destination, because when I was doing the SPAN with the physical port as the source, I see just one copy. Here is my current config. Do you see any problems with it? Is there something I missed with using Vlan as the source? The Nexus 9K is in a VPC setup. The v1023 only exists on two interfaces - (one physical E1/22 and another VPC Po29, which are the source ports in my original SPAN config. Thanks!
vlan access-map nmsprd010 10
  match ip address nmsprd010
  action forward
monitor session 3
  source vlan 1023 rx
  no shut
Config looks ok. Most likely a bug.
