N2K-B22DELL-P FEX Blade module support on N9K-C93180YC-FX on 10.5(1)
vlk-vincent
Hello Community,
please, is the N2K-B22DELL-P FEX Blade module supported on N9K-C93180YC-FX with NX-OS version 10.5(1)?
We see the FEX online, but all HIF ports on FEX are still in "notconnect" state. We tested this behavior on multiple FEX modules and Parent switches.
example:
FEX: 104 Description: FEX0104   state: Online
  FEX version: 10.5(1) [Switch version: 10.5(1)]
  FEX Interim version: 10.5(1)
  Switch Interim version: 10.5(1)
  Extender Model: N2K-B22DELL-P,  Extender Serial: <redacted>
  Part No: 73-14668-02
  Bay: B2
  Enclosure: Dell M1000e Slot B2
  Service Tag: HRXP002
  Card Id: 210, Mac Addr: a8:9d:21:36:49:02, Num Macs: 64
  Module Sw Gen: 21  [Switch Sw Gen: 21]
 pinning-mode: static    Max-links: 1
  Fabric port for control traffic: Eth1/9
  FCoE Admin: false
  FCoE Oper: true
  FCoE FEX AA Configured: false
  Fabric interface state:
    Po104 - Interface Up. State: Active
    Eth1/9 - Interface Up. State: Active
    Eth1/10 - Interface Up. State: Active
  Fex Port        State  Fabric Port
       Eth104/1/1  Down       Po104
       Eth104/1/2  Down       Po104
       Eth104/1/3  Down       Po104
       Eth104/1/4  Down       Po104
       Eth104/1/5  Down       Po104
       Eth104/1/6  Down       Po104
       Eth104/1/7  Down       Po104
       Eth104/1/8  Down       Po104
       Eth104/1/9  Down       Po104
      Eth104/1/10  Down       Po104
      Eth104/1/11  Down       Po104
      Eth104/1/12  Down       Po104
      Eth104/1/13  Down       Po104
      Eth104/1/14  Down       Po104
      Eth104/1/15  Down       Po104
      Eth104/1/16  Down       Po104
Logs:
03/21/2025 14:53:39.310945: Module register received
03/21/2025 14:53:39.311178: State timer stopped
03/21/2025 14:53:39.312281: Registration response sent
03/21/2025 14:53:39.356722: State timer stopped
03/21/2025 14:53:39.357073: Module Online Sequence
03/21/2025 14:53:40.882619: Module Online
According to FEX and N9K compatibility matrix, this modules should be supported:
https://www.cisco.com/c/dam/en/us/td/docs/Website/datacenter/fexmatrix/fexmatrix.html
I will provide any additional information if needed,
many thanks in advance.
Hello marce1000,
thank you for reply. We managed to get it working, so the N2K-B22DELL-P FEX Blade module *is* supported on N9K-C93180YC-FX with NX-OS version 10.5(1). After changing the IO module slots, the culprit was in physical connection of IO module in DELL Blade chassis.
marce1000
  - Yet , I don't find it in https://www.cisco.com/c/dam/en/us/td/docs/Website/datacenter/fexmatrix/fexmatrix.html ?
  M.
Hello marce1000,
