HI Everyone,
I have a problem about multicast on N5672.The unicast routing operating by OSPF,there are two ports connect to other two N5672 in this device,one port is E1/10,the other port is E1/11,we only issue "ip pim sparse-mode" on E1/10,but we can see E1/11 in incoming interface.Just as this:
N5672UP (config)# sh ip mroute
(192.168.6.4/32, 239.2.1.1/32), uptime: 00:33:04, static ip pim mrib
Incoming interface: Ethernet1/11, RPF nbr: 172.16.1.100 <<<<<E1/11 not config "ip pim sparse-mode"
Outgoing interface list: (count: 1)
Ethernet1/20, uptime: 00:33:04, static, pim
system: version 7.1(5)N1(1)
So,i feel it's abnomal.Do you have the same issue?Is there any explain?
BR&Thanks
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
