N7K-C7010 , N7K-F248XP-25E unknow showing
Ramprasad2
I have Cisco Switch Nexus N7K-C7010 in this switch i have install 2 module
1 PID N7K-M148GT-11   ( support in nexus )
2 PID N7K-F248XP-25E    ( not support )
3 Running IOS Version Cisco ( bootflash:/n7000-s1-kickstart.6.1.1.bin  and bootflash:/n7000-s1-dk9.6.1.1.bin
as per Cisco document all module support in N7K-C7010 For reference attached link (https://www.cisco.com/c/en/us/products/collateral/switches/nexus-7000-series-switches/Data_Sheet_C78-437762.html )
4 how to resolved this issue
5 below attached output sheet
Switch# show module
Mod  Ports  Module-Type                         Model              Status
1    0      Unknown Module                                         powered-dn
2    0      Unknown Module                                         powered-dn
3    48     101001000 Mbps Ethernet Module    N7K-M148GT-11      ok
5    0      Supervisor module-1X                N7K-SUP1           active
Mod  Power-Status  Reason
1    powered-dn     Unknown card (Could not get software-card-id)
2    powered-dn     Unknown card (Could not get software-card-id)
Mod  Sw              Hw
3    6.1(1)          1.5
5    6.1(1)          1.6
Mod  MAC-Address(es)                         Serial-Num
3    68-ef-bd-7b-74-30 to 68-ef-bd-7b-74-64  JAF1408AQRE
5    00-26-98-18-cc-28 to 00-26-98-18-cc-30  JAF1411BALF
Mod  Online Diag Status
3    Pass
5    Pass
Xbar Ports  Module-Type                         Model              Status
1    0      Fabric Module 1                     N7K-C7010-FAB-1    ok
2    0      Fabric Module 1                     N7K-C7010-FAB-1    ok
3    0      Fabric Module 1                     N7K-C7010-FAB-1    ok
Xbar Sw              Hw
1    NA              1.1
2    NA              1.1
3    NA              1.1
Xbar MAC-Address(es)                         Serial-Num
1    NA                                      JAF1411ALAD
2    NA                                      JAF1411ALBD
3    NA                                      JAF1411AGER
 this terminal session
switch# show  incompatibility-all  system bootflashsup-1n7000-s1-dk9.6.1.1.bin
Checking incompatible configuration(s) for vdc 'switch'
switch# show  incompatibility-all  system bootflashsup-1n7000-s1-kickstart.4.2.2a.bin
Failure in image extraction
switch# show inventory
NAME Chassis,  DESCR Nexus7000 C7010 (10 Slot) Chassis
PID N7K-C7010           ,  VID V02 ,  SN TBM14149162
NAME Slot 1,  DESCR Unknown Module
PID N7K-F248XP-25E      ,  VID V01 ,  SN JAF1745AAPN
NAME Slot 2,  DESCR Unknown Module
PID N7K-F248XP-25E      ,  VID V01 ,  SN JAF1745BLRL
NAME Slot 3,  DESCR 101001000 Mbps Ethernet Module
PID N7K-M148GT-11       ,  VID V07 ,  SN JAF1408AQRE
NAME Slot 5,  DESCR Supervisor module-1X
PID N7K-SUP1            ,  VID V09 ,  SN JAF1411BALF
NAME Slot 11,  DESCR Fabric card module
PID N7K-C7010-FAB-1     ,  VID V03 ,  SN JAF1411ALAD
NAME Slot 12,  DESCR Fabric card module
PID N7K-C7010-FAB-1     ,  VID V03 ,  SN JAF1411ALBD
NAME Slot 13,  DESCR Fabric card module
PID N7K-C7010-FAB-1     ,  VID V03 ,  SN JAF1411AGER
NAME Slot 33,  DESCR Nexus7000 C7010 (10 Slot) Chassis Power Supply
PID N7K-AC-6.0KW        ,  VID V05 ,  SN ART1927F01H
NAME Slot 34,  DESCR Nexus7000 C7010 (10 Slot) Chassis Power Supply
PID N7K-AC-6.0KW        ,  VID V01 ,  SN DTM140705LR
NAME Slot 36,  DESCR Nexus7000 C7010 (10 Slot) Chassis Fan Module
PID N7K-C7010-FAN-S     ,  VID V01 ,  SN FOX1418XACN
NAME Slot 37,  DESCR Nexus7000 C7010 (10 Slot) Chassis Fan Module
PID N7K-C7010-FAN-S     ,  VID V01 ,  SN FOX1418XALQ
NAME Slot 38,  DESCR Nexus7000 C7010 (10 Slot) Chassis Fan Module
PID N7K-C7010-FAN-F     ,  VID V02 ,  SN FOX1247XA3K
NAME Slot 39,  DESCR Nexus7000 C7010 (10 Slot) Chassis Fan Module
PID N7K-C7010-FAN-F     ,  VID V02 ,  SN FOX1247XA2G
switch# sh module
Mod  Sw              Hw
3    6.1(1)          1.5
5    6.1(1)          1.6
switch# install
  all          Upgrade the system
  fan-module   Install fan module
  license      Install license
  module       Upgrade for module
  xbar-module  Install xbar module
switch# install module
  1-10  Enter module index
switch# install module 1
  cmp   Upgrade cmp
  epld  Install EPLD from EPLD image
switch# install module 1 cmp
  system  System Image
switch# install module 1 cmp system
  bootflash  Local URI containing the system image
  slot0      Local URI containing the system image
  volatile   Local URI containing the system image
switch# install module 1 cmp system bootflash
  bootflash
  bootflashmodule-5
  bootflashsup-1
  bootflashsup-active
  bootflashsup-local
  bootflash1
  bootflashJAF1346AEPQ_136896895.lic
  bootflashethpm_act_logs.log
  bootflashethpm_im_tech.log
  bootflashethpm_lacp_tech.log
  bootflashethpm_mts_details.log
  bootflashethpm_pcm_tech.log
  bootflashethpm_pss_gldb_tech.log
  bootflashethpm_syslogs.log
  bootflashethpm_tech.log
  bootflashethpm_vlan_tech.log
  bootflashlost+found
  bootflashn7000-s1-dk9.4.2.2a.bin
  bootflashn7000-s1-dk9.6.1.1.bin
  bootflashn7000-s1-kickstart.4.2.2a.bin
  bootflashn7000-s1-kickstart.6.1.1.bin
  bootflashstat
  bootflashvdc_2
  bootflashvdc_3
  bootflashvdc_4
  bootflashvlan.dat
switch# install module 1 cmp system bootflash7000-s1-kickstart.4.2.2a.bin
Module 1 not online...
switch# install module 1 cmp system bootflashn7000-s1-kickstart.4.2.2a.bin
switch#
switch# install
  cmp   Upgrade cmp
switch# install module 1 epld
  bootflash  Local URI containing EPLD Image
  slot0      Local URI containing EPLD Image
  volatile   Local URI containing EPLD Image
switch# install module 1 epld bootflash
  bootflash
  bootflashmodule-5
  bootflashsup-1
  bootflashsup-active
  bootflashsup-local
  bootflash1
  bootflashlost+found
  bootflashstat
  bootflashvdc_2
  bootflashvdc_3
  bootflashvdc_4
  bootflashvlan.dat
switch# install module 1 epld bootflashn7000-s1-kickstart.6.1.1.bin
Failed to get Module HW version.
Failed to get Module EPLD information, Exiting..
switch#
switch#
switch#
switch#
switch# install
switch# install license
  bootflash  Specify URL for license file
  slot0      Specify URL for license file
  usb1       Specify URL for license file
  usb2       Specify URL for license file
switch# install license bootflash
  bootflash
  bootflashmodule-5
  bootflashsup-1
  bootflashsup-active
  bootflashsup-local
  bootflash1
  bootflashlost+found
  bootflashstat
  bootflashvdc_2
  bootflashvdc_3
  bootflashvdc_4
  bootflashvlan.dat
switch# install license bootflashJAF1346AEPQ_136896895.lic
Installing license failed License file already exists. Please use a different file name for the new license.
switch#
switch# install
switch# install all
  CR
  kickstart  Boot-variable name
  parallel   Parallel upgrade linecards in the system
  system     Boot-variable name
switch# install all kickstart
  bootflash  Enter image uri
  ftp        Enter image uri
  scp        Enter image uri
  sftp       Enter image uri
  slot0      Enter image uri
  tftp       Enter image uri
  usb1       Enter image uri
  usb2       Enter image uri
  volatile   Enter image uri
switch# install all kickstart bootflash
  bootflash
  bootflashmodule-5
  bootflashsup-1
  bootflashsup-active
  bootflashsup-local
  bootflash1
  bootflashlost+found
  bootflashstat
  bootflashvdc_2
  bootflashvdc_3
  bootflashvdc_4
  bootflashvlan.dat
switch# install all ?
  <CR>
switch# install all
Verifying image bootflash:/n7000-s1-kickstart.6.1.1.bin for boot variable "kickstart".
[####################] 100% -- SUCCESS
Verifying image bootflash:/n7000-s1-dk9.6.1.1.bin for boot variable "system".
Verifying image type.
Extracting "lc1n7k" version from image bootflash:/n7000-s1-dk9.6.1.1.bin.
Extracting "bios" version from image bootflash:/n7000-s1-dk9.6.1.1.bin.
Extracting "system" version from image bootflash:/n7000-s1-dk9.6.1.1.bin.
Extracting "kickstart" version from image bootflash:/n7000-s1-kickstart.6.1.1.bin.
Extracting "cmp" version from image bootflash:/n7000-s1-dk9.6.1.1.bin.
Extracting "cmp-bios" version from image bootflash:/n7000-s1-dk9.6.1.1.bin.
Performing module support checks.        [####################] 100% -- SUCCESS
Notifying services about system upgrade.        [####################] 100% -- SUCCESS
Compatibility check is done:
Module  bootable          Impact  Install-type  Reason
     3       yes  non-disruptive          none
     5       yes  non-disruptive          none
Images will be upgraded according to following table:
Module       Image                  Running-Version(pri:alt)           New-Version  Upg-Required
     3      lc1n7k                                    6.1(1)                6.1(1)            no
     3        bios    v1.10.17(04/25/11):  v1.10.17(04/25/11)    v1.10.17(04/25/11)            no
     5      system                                    6.1(1)                6.1(1)            no
     5   kickstart                                    6.1(1)                6.1(1)            no
     5        bios     v3.22.0(02/20/10):  v3.22.0(02/20/10)     v3.22.0(02/20/10)            no
     5         cmp                                    6.1(1)                6.1(1)            no
     5    cmp-bios                                  02.01.05              02.01.05            no
Do you want to continue with the installation (y/n)?  [n] y
Install is in progress, please wait.
Performing runtime checks.        [####################] 100% -- SUCCESS
Setting boot variables.
Performing configuration copy.
Module 3: Refreshing compact flash and upgrading bios/loader/bootrom.
Warning: please do not remove or power off the module at this time.
Module 5: Refreshing compact flash and upgrading bios/loader/bootrom.
Install has been successful.
switch# 2022 Dec 17 12:35:29 switch %$ VDC-1 %$ %COPP-2-COPP_PROFILE_DIFF: CoPP Default Profile may have changed, please check the diffs using show copp diffswitch# show  module
3    48     10/100/1000 Mbps Ethernet Module    N7K-M148GT-11      ok
5    0      Supervisor module-1X                N7K-SUP1           active *
Mod  Sw              Hw
3    6.1(1)          1.5
5    6.1(1)          1.6
3    Pass
5    Pass
Xbar Sw              Hw
1    NA              1.1
2    NA              1.1
3    NA              1.1
1    NA                                      JAF1411ALAD
2    NA                                      JAF1411ALBD
3    NA                                      JAF1411AGER
* this terminal session
switch# show  module
Mod  Sw              Hw
3    6.1(1)          1.5
5    6.1(1)          1.6
3    Pass
5    Pass
Xbar Sw              Hw
1    NA              1.1
2    NA              1.1
3    NA              1.1
1    NA                                      JAF1411ALAD
2    NA                                      JAF1411ALBD
3    NA                                      JAF1411AGER
switch# show  module
Mod  Sw              Hw
3    6.1(1)          1.5
5    6.1(1)          1.6
6 Replies 6
Christopher Hart
Hello!
The N7K-F248XP-25E module is supported starting with NX-OS software release 6.1(2). This Nexus 7010 switch is currently running NX-OS software release 6.1(1). In order to bring these N7K-F248XP-25E modules online, you will need to upgrade the NX-OS software of the switch to NX-OS software release 6.1(2) or higher.
I hope this helps - thank you!
-Christopher
Apologies, I forgot to link to supporting documentation! This is documented in Table 3 of the Cisco Nexus 7000 F2-Series Enhanced 48-Port Fiber 1 and 10 Gigabit Ethernet Module Data Sheet document.
-Christopher
thank you for suggestion but i have doubt when
This iOS version needs in 7000 chassis with 4 module support ( 6.1.2 or latter)
My cases I have 7000 chassis with 10 module support and for this iOS version Cisco NX-OS Software Release 4.0 or later.
Why I am installation 6.1.2 or latter
For reference I have attached doc link see please https://www.cisco.com/c/en/us/products/collateral/switches/nexus-7000-series-switches/Data_Sheet_C78-437762.html even this doc update
Updated:January 17, 2021
even you share link
Updated:January 17, 2021 as i used doc link
Cisco Nexus 7000 4-Slot Switch
Cisco Nexus 7000 9-Slot Switch
Cisco Nexus 7000 10-Slot Switch
Cisco Nexus 7000 18-Slot Switch
Product compatibility
Supports all Cisco Nexus 7000 Series Supervisor and I/O modules except the following:
N7K-SUP1
N7K-M132XP-12
N7K-M148GS-11
N7K-M148GT-11
N7K-F132XP-15
Does not use fabric modules
Supports Fabric2 modules
Does not support Fabric1 modules
Supports Fabric1 and Fabric2 modules
Max local switching capacity
600 Gbps
600 Gbps
600 Gbps
600 Gbps
Max inter-slot switching capacity
440 Gbps
550 Gbps
550 Gbps
550 Gbps
Software compatibility
Cisco NX-OS Software Release 6.1(2) or later
Cisco NX-OS Software Release 5.2 or later
Cisco NX-OS Software Release 4.1 or later
Hello!
The "Software Compatibility" section of the Nexus 7000 Series Switches Data Sheet you're linking references the minimum NX-OS software that needs to run on a supervisor engine (N7K-SUP1, N7K-SUP2, N7K-SUP2E) in order for the supervisor engine to properly boot up and execute when inserted in the relevant chassis. For example, if I had an N7K-SUP1 supervisor inserted in a Nexus 7010 running NX-OS 4.0, I could not remove that supervisor engine and insert it into a Nexus 7009 or 7004 and expect the supervisor to boot up properly, since the Nexus 7009 chassis is supported starting with NX-OS 5.2 and the Nexus 7004 chassis is supported starting with NX-OS 6.1(2). An upgrade of the NX-OS software running on that supervisor engine would be needed prior to me inserting it into either the Nexus 7009 or 7004 chassis models.
The "Product Compatibility" section of that same data sheet simply indicates the line cards that are physically compatible with the chassis. Each line card does have its own specific minimum NX-OS software needed for the line card itself to boot up, which are detailed in the individual line card's data sheet. This is why I referenced Table 3 of the Cisco Nexus 7000 F2-Series Enhanced 48-Port Fiber 1 and 10 Gigabit Ethernet Module Data Sheet document, which indicates that the minimum NX-OS software release needed for the N7K-F248XP-25E line card is NX-OS 6.1(2).
I hope this helps clarify things - thank you!
-Christopher
thank you shared your suggestion.
In the case i have one sup(  supervisor engine (N7K-SUP1 ) engine and running with 6.1.1 IOS image and as i told you before 2 module insert one is M series and its support but  second is F series module and its not support.
