Need to add allowed vlan to port-channel / vpc
AlexFer
Hello experts,
my question seems to be answered by add new vlan in vpc and portchannel however, since this is my first time doing on live switch, I seek confirmation.
I required to add vlans to a trunk being a port-channel and a VPC without downtime.
Obviously, my intention is to update Port-Channel on both VPC Peers, but there may be a practical short delay during which there will be inequality. As you see below, it’s a “Type 1” VPC which means “parameters must match on both vPC Peers, otherwise vPC is not operational”.
My question: is ‘Allowed VLANs’ considered a consistency parameter or not? If not, then short delay during inequality won’t cause downtime, correct?
R's, Alex
hostname-7010-1# show vpc consistency-parameters vpc 200
    Legend:
        Type 1 : vPC will be suspended in case of mismatch
Name                        Type  Local Value            Peer Value
lag-id                      1     [(abcd,                [(abcd,
                                  0-23-4-ee-be-12, 80c8, 0-23-4-ee-be-12, 80c8,
                                   0, 0), (abcd,          0, 0), (abcd,
                                  0-23-4-ee-be-6c, 8002, 0-23-4-ee-be-6c, 8002,
                                   0, 0)]                 0, 0)]
mode                        1     active                 active
STP Port Type               1     Normal Port            Normal Port
STP Port Guard              1     None                   None
STP MST Simulate PVST       1     Default                Default
Native Vlan                 1     1                      1
Port Mode                   1     trunk                  trunk
MTU                         1     1500                   1500
Duplex                      1     full                   full
Speed                       1     10 Gb/s                10 Gb/s
Allowed VLANs               -     18,22,24,30,34,40,50-5 18,22,24,30,34,40,50-5
                                  3,81,85,88,90-91,100-1 3,81,85,88,90-91,100-106
Local suspended VLANs       -     -                      -
hostname-7010-1# show running-config cfs
version 5.2(1)
cfs eth distribute
Correct. Your understanding is correct.
It does not matter on which peer you make changes, the vpc operational secondary will be always the one who suspend the vlan.
Stay safe,
Sergiu
Sergiu.Daniluk
Hi @AlexFer
Technically, allowed vlans is not a type 1 inconsistency as a range, however, it is per-vlan inconsistancy. What do I mean by this is if a vlan is configured and allowed on only one side of the vpc port-channel, then the vpc operational secondary switch will bring ONLY that specific vlan in suspended state on the respective vpc-enabled port-channel.
Example (as they always clarify better the story):
! initial config:
interface port-channel119
  switchport
  switchport mode trunk
  switchport trunk allowed vlan 20
! start config changes:
N9K-1 (vpc operational secondary)
N9K-1(config-if)# int po 119
N9K-1(config-if)# switchport trunk allowed vlan add 21
2020 Oct  6 17:37:29 N9K-1%ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLAN/BDs 21 on Interface port-channel119 are being suspended. (Reason: Vlan is not configured on remote vPC interface)
! nothing changed on N9K-2 (operational primary)
! continuing with the cfg
N9K-2(config-if)# int po 119
N9K-2(config-if)# switchport trunk allowed vlan add 21
2020 Oct  6 17:37:48 N9K-1 %ETHPORT-3-IF_ERROR_VLANS_REMOVED: VLAN/BDs 21 on Interface port-channel119 are removed from suspended state
Hope it is clear and it helps. Good luck with the changes.
Stay safe,
Sergiu
Hi Sergiu,
from your response, I understand that only those VLANs matched by "allowed vlan" on both VPC Peers will allowed on that port-channel/vpc, and there's no impact on other VLANs on that port-channel/vpc due to "switchport trunk allowed vlan add" command - correct?
Does it matter on which VPC Peer I make the change first? (You make first change on "operational secondary" VPC Peer first.)
R's, Alex
Stay safe,
Sergiu
Hi Sergiu,
a subsequent question: I understand is a suspended VLAN affects that VLAN's traffic across the VPC Peer-link, but does it prevent the traffic on the actual port-channel - will that VLAN's traffic still be trunked?
R's, Alex
