03-06-2020 05:48 AM
Helle every body.
I would like to know if nexus 3000 series are autonomous switches.Like 5000 series.
If i can create a vpc domain , put svi , ect.....
Thank you !
03-06-2020 10:12 PM
Hello Thierry,
Yes, those n3ks support L3 features, vPC and so on, but it is all a combination of model, software version, and licenses. For example:
● High availability
◦ Virtual Port Channel (vPC) technology provides Layer 2 multipath through the elimination of Spanning Tree Protocol. It also enables fully utilized bisectional bandwidth and simplified Layer 2 logical topologies without the need to change the existing management and deployment models.
◦ The 64-way Equal-Cost Multipath (ECMP) routing enables the use of Layer 3 fat-tree designs. This feature allows organizations to prevent network bottlenecks, increase resiliency, and add capacity with little network disruption.
◦ Advanced reboot capabilities include hot and cold patching and fast reboot capabilities.
◦ The switch uses hot-swappable Power-Supply Units (PSUs) and fans.
● Purpose-built NX-OS operating system with comprehensive, proven innovations
◦ Power-on Autoprovisioning (POAP) enables touchless bootup and configuration of the switch, drastically reducing provisioning time.
◦ Cisco Embedded Event Manager (EEM) and Python scripting enable automation and remote operations in the data center.
◦ Advanced buffer monitoring reports real-time buffer utilization per port and per queue, which allows organizations to monitor traffic bursts and application traffic patterns.
◦ EtherAnalyzer is a built-in packet analyzer for monitoring and troubleshooting control-plane traffic and is based on the popular Wireshark open-source network protocol analyzer.
◦ Complete Layer 3 unicast and multicast routing protocol suites are supported, including Border Gateway Protocol (BGP), Open Shortest Path First (OSPF), Enhanced Interior Gateway Routing Protocol (EIGRP), Routing Information Protocol Version 2 (RIPv2), Protocol Independent Multicast Sparse Mode (PIM-SM), Source-Specific Multicast (SSM), and Multicast Source Discovery Protocol (MSDP).
So make sure to review the model and software version so that you have anything you need working.
Keep us posted, please proceed to rate all helpful posts, and mark as validated answer if this is the answer to your question,
David Castro,
