Nexus 5596 Loader> Problem
collrbbrt
Hi guys I have a brand-new cisco Nexus 5596 Switch and I want to install kickstart and system image.
Problem is: when switch starts I only get the word Loader>
When I type dir command I only get
loader> dir
bootflash:
lost+found
There is nothing in bootflash.
Also I can not see the USB drive even when it is connected.
How can I recover from this ?
5 Replies 5
marce1000
 - What options do you have when typing :
               loader> ?
 M.
collrbbrt
Hi Marce this is what I see.
loader> ?
? Print the command list boot Boot an image
dir List the directory content help Print the command list or
reboot Reboot the system resetcmos Reset CMOS to factory defa
serial Serial console settings set Set network configuration
show Show loader configuration
  - Check if you can get an image on the Nexus by using these commands :
             loader> boot tftp://<tftp_server_ip>/n5000-uk9-kickstart.7.0.3.N1.1.bin
    switch(boot)> load bootflash:/n5000-uk9.7.0.3.N1.1.bin
   switch(boot)>  install all
                     Of course you need to change the image name(s) , according to available software
 M.
marce1000
  - Also have a look at : https://www.youtube.com/watch?v=JskVWVY5U00
 M.
This Video uploaded for better access on the main video. Main Link of this video is here. https://supportforums.cisco.com/t5/data-center-videos/how-to-restore-a-cisco-nexus-switch-from-loader-prompt/ba-p/3101970 Original link video seems to BW limitation enabled. This great video helped me to ...
collrbbrt
Thank you @marce1000
