Nexus 7010 recommended software
Hello Team,
I have nexus 7010 switch current version 6.1(5). Could you suggest recommended version. I am seeing in cisco portal
recommended version is showing
7.3(5)D1(1) and
8.2(5) . Could you suggest which is recommended version for 7010.
Kanhu
6 Replies 6
jlopezbo
Hello Krath
Both versions are recommend by developer
However there will be some difference between the NX-OS trends
For example M1 modules are no supported in 8 codes
Link for release notes
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus7000/sw/release/notes/cisco_nexus7000_release_notes_8x.html
 Cisco Nexus 7000 Supervisor 1 modules, M1 series modules (XL and non-XL modes), FAB-1 modules, F2 series modules are not supported in Cisco NX-OS Release 8.x.
7.3(5)D1(1)  will not support
The following list provides the unsupported hardware for Cisco NX-OS Release 7.3(0)DX(1), Cisco NX-OS Release 7.3(1)D1(1), Cisco NX-OS Release 7.3(2)D1(1):
  • N7K-M108X2-12
  • N7K-M148GT-11
  • N7K-M132XP-12
  • N7K-M148GS-11
  • N7K-C7010-FAB-1
  • N7K-C7018-FAB-1
  • N7K-F132XP-15
  • Cisco Nexus 7000 Supervisor 1 Module
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/7_x/nx-os/release/notes/7x_nx-os_release_note.html
What modules are running in your switch. Can you run a "show module"
Please find below.
9508-1-Right# sh module
Mod Ports Module-Type Model Status
1 52 48x1/10G SFP+ 4x40G Ethernet Module N9K-X9464PX ok
2 52 48x1/10G-T 4x40G Ethernet Module N9K-X9464TX2 ok
22 0 Fabric Module N9K-C9508-FM ok
23 0 Fabric Module N9K-C9508-FM ok
24 0 Fabric Module N9K-C9508-FM ok
26 0 Fabric Module N9K-C9508-FM ok
27 0 Supervisor Module N9K-SUP-A+ active *
28 0 Supervisor Module N9K-SUP-A+ ha-standby
29 0 System Controller N9K-SC-A active
30 0 System Controller N9K-SC-A standby
Mod Sw Hw Slot
1 9.2(4) 1.4 LC1
2 9.2(4) 1.2 LC2
22 9.2(4) 2.5 FM2
23 9.2(4) 2.5 FM3
24 9.2(4) 2.5 FM4
26 9.2(4) 2.5 FM6
27 9.2(4) 1.1 SUP1
28 9.2(4) 1.1 SUP2
29 9.2(4) 2.0 SC1
30 9.2(4) 2.0 SC2
Krath
The show module provide belongs to a Nexus 9k. I tough you had a Nexus Nexus 7010.
Your concern regarding the recommend code is regard a Nexus 9k or Nexus 7k?
This is for 7K only. Please find attached screen shot. Kindly suggest.
Thanks for the information
In your case you can not move to the recommend version because the Module N7k-F132XP-15 is not supported in any of the recommend codes
The latest version you can move is  6.2(24a) where the hardware running in your switch is still supported
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/6_x/nx-os/release/notes/62_nx-os_release_note.html#pgfId-809255
Also
N7k-F132XP-15 is already end of life since last year
N7k-M148GT-11L is not end of life yet but will be end of life next year
Recommend you to upgrade your F1 module which is already end of life
Hi Krath,
I see in the capture, you have fabric 1 module, so that you cannot upgrade to the recommended version (8.2.5 and 7.3.5),
If you upgrade to that recommended version, I used to upgrade to 8.2.5 and 7.3.5, the Fabic module show "Unsupported". I must downgrade to 6.2.12.
---------show module------
Xbar Ports Module-Type Model Status
1 0 Fabric module NA powered-dn
2 0 Fabric module NA powered-dn
3 0 Fabric module NA powered-dn
4 0 Fabric module NA powered-dn
5 0 Fabric module NA powered-dn
Xbar Power-Status Reason
1 powered-dn Unsupported/Unknown Module
2 powered-dn Unsupported/Unknown Module
3 powered-dn Unsupported/Unknown Module
4 powered-dn Unsupported/Unknown Module
5 powered-dn Unsupported/Unknown Module
Please let me know if you can upgrade to recommended version.
