Nexus 9k erase config / factory reset
moakintola
Hello
I write erase a nexus 9k switch. After reload where it ask
hey guys.... I want to upgrade one nexus 9k... so during fresh boot, when presented with this:
2023 Oct 4 18:57:09 switch %$ VDC-1 %$ %POAP-2-POAP_INFO: [FLM270403DE-6C:29:D2:19:02:9B] - Start DHCP v4 session
2023 Oct 4 18:57:09 switch %$ VDC-1 %$ %POAP-2-POAP_DHCP_DISCOVER_START: [FLM270403DE-6C:29:D2:19:02:9B] - POAP DHCP Discover phase started
2023 Oct 4 18:57:09 switch %$ VDC-1 %$ %POAP-2-POAP_INFO: - Abort Power On Auto Provisioning [yes - continue with normal setup, skip - bypass password and basic configuration, no - continue with Power On Auto Provisioning] (yes/skip/no)[no]:
2023 Oct 4 18:57:09 switch %$ VDC-1 %$ %POAP-2-POAP_FAILURE: [FLM270403DE-6C:29:D2:19:02:9B] - POAP DHCP discover phase failed
2023 Oct 4 18:57:11 switch %$ VDC-1 %$ %POAP-2-POAP_INFO: - Abort Power On Auto Provisioning [yes - continue with normal setup, skip - bypass password and basic configuration, no - continue with Power On Auto Provisioning] (yes/skip/no)[no]:
I used skip option instead of yes.
Now, I cannot login using old password. Even after switch to boot and resent admin password, I still cannot login
Please help
f00z
Level 3
Level 3
just log in as admin with no password?
Corri S
These are the admin password reset steps for anyone who wants to know.
  1. Power on nexus
  2. Ctrl + c, this puts you in loader
  3.  use this command ..   cmdline recoverymode=1
  4. Then this command ..    Dir    …this is gonna find the latest NX OS in bootflash
  5. Boot the latest nx os .bin
  6. Now we're in switch(boot)# where we can CONF T
  7. Switch(boot)(config)# admin-password <secret squirrel>   ...
Have you tried deleting the username and then remaking it with the old password?
marce1000
                 - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuh85186
 M.
superation237
So if you do the admin-password thing and reset the password and you are getting the above message you HAVE to say YES to the prompts. If you SKIP it will send you to a different login prompt and your newly changed password won't work. Say YES to the prompt and the password login you changed will work (as with most things in life I learned the hard way).
