08-07-2024 08:29 AM
Hello everyone,
We have two 400G links flapping and I am trying to find a reason why.
I am trying to understand the meaning of "show pie eventdb link-down-rca detail" report.
What the report says is:
Reason: Software Bug. Laser is not enabled.
Link Down Reason :Software Bug. Laser is not enabled.
Do you think it is actual NX-OS SW bug or some QSFP mis-compatibility?
This report is from 93600CD-GX, running 10.3.3F
08-07-2024 09:42 AM
- You may find this informative : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwi71532
although this one won't help
+ Also issue the command Switch# show interface <interface name> transceiver details
look at the Transmit Fault Count , if available
+ Look at the interface counters
+ Make sure all connections are solid
+ Check logs on the nexus : preferred = using a syslog server for connecting logs because then you have an easier access
to review logging in time
+ Try another SFP('s) if available
M.
08-08-2024 12:16 AM
Thank you for the information marce1000. Do you have any experience with the command suggested in the bug ID?
I find information about it so far only in the N7K command reference guide:
Cisco Nexus 7000 Series NX-OS Interfaces Command Reference - S Commands [Cisco Nexus 7000 Series Switches] - Cisco
For 9Ks, I was only able to find it in 10.4.x configuration command reference guide, but only in the section New Commands:
Cisco Nexus 9000 Series NX-OS Command Reference (Configuration Commands), Release 10.4(x) - New, Changed, and Deprecated Configuration Commands [Cisco Nexus 9000 Series Switches] - Cisco
I will test it in the lab and share what's the outcome.
08-08-2024 01:32 AM - edited 08-08-2024 01:37 AM
- No , I am not using the product myself , only doing support ; you may try it :
system default link-fail laser-on
But according to the bug report it doesn't work
- Personally I would chose for the upgrade to https://software.cisco.com/download/home/286325342/type/282088129/release/10.3(5)
(possibly benefiting from other bugfixes and it it an advisory release)
+ Then check output from show pie eventdb link-down-rca detail
again and check if the bug condition is still reported (or not)
M.
