Showing results forĀ
Search instead forĀ
Did you mean:Ā
Nexus7702 not showing success login, only failed
ezequiel7
Hi Community,
Is there any way to have the logs after someone logged to the N7K devices successfully. The auth and authpriv levels are in  6 and the following commands not working on N7702 (version 8.2(6) ).
login on-failure log
login on-success log
Currently we only have the failed login logs.
2022 Nov 14 10:18:16 N7702-DC-C1  %AUTHPRIV-5-SYSTEM_MSG: Login failed for user admin - dcos_sshd
Are this issue solved?
Hi @MHM Cisco World not yet. I tried enable auth and authpriv level log to 6
Can I see nexus config
Sorry @MHM Cisco World ,
We talked with the TAC, they said the show accounting log show the succesful logins. Thanks for your time and interest
