NX-OS EIGRP Filtering
TONY SMITH
In IOS you can configure EIGRP outbound filtering with an extended access list, the first entry defines the prefix (or prefixes) and the second entry defines the neighbour(s) that you want to permit or deny distribution to.  Is there a way to do the same for NX-OS?  I have found for redistribution that I can't make head nor tail of the way it should work using an access-list, so have always used prefix-lists.  But these only define the route, not the neighbour.
Tony S
