phisical ports distributions to vpc nexus 3232c
Hi, I need to configure vPCs on nexus 3232c my question is: How must distribute the phisical ports to the vPC? should do a vPC between  interface 1/1 & 1/17 or interface 1/1 &1/2? How are the ASIC´s distributions 1 slice to 16 ports, 1 slice to 8 ports, 1  slice to 4 ports? if one ASIC fail I don't want to lost the vPC
2 Accepted Solutions
Sergiu.Daniluk
Hi @Orlando Chaparro
Nexus 3232c has only one ASIC - Broadcom Tomahawk2 to be more precise. There are no slices. So you can distribute the ports as you wish. If the ASIC fails, all switch/ports fails.
Take care,
Sergiu
Sergiu.Daniluk
Take care,
Sergiu
Thanks Sergiu
