Problem with configure replace on N7706 in Admin VDC
Hello everyone,
We have a problem with restoring the previous configuration using the "configure replace" command on N7706. Even with simple configuration changes like setting the motd banner and calling config restore after that, restore fails with the error message:
Version match between user file and running configuration.
User config file does not contain mandatory [vlan 1] command.
Pre-check for User config FAILED
The "show config-replace log exec" command output displays the message "ERROR: Log Not Available". The commands are issued in Admin-VDC by the admin user with the network-admin role. The NX-OS version is 8.2(6).
Does anyone have an idea why config restore fails?
Mark Elsen
  - It seems like any vlan1 related settings must be present in the config that you are trying to restore ; you may try to add those (too) ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi @Mark Elsen ,
The problem is that there are no VLANs or related settings configured in Admin VDC, and the backup file made from running or startup configuration couldn't contain those either. I have already tried to set available VLAN settings such as "vlan dot1Q tag native" and others just to test, but the same error pops up every time.
If I create a backup file from the running configuration, that backup file should be identical to the running config. There is not much sense in that error regarding vlan1-related settings which don't exist in the original configuration. That's why I'm puzzled about it.
  - Could be a bug  ; you could for instance try with : https://software.cisco.com/download/home/284809080/type/282088129/release/8.4(8)
  M.
       Beauty and terror
      Just keep going
       No feeling is final
