problem with permanent license installation
fedcre
Hi folks,
i've some problems installing the  permanent licence file on 1000v , running ver 4.2.1.SV1 5.2
Software
  loader:    version unavailable [last: loader version not available]
  kickstart: version 4.2(1)SV1(5.2)
  system:    version 4.2(1)SV1(5.2)
  kickstart image file is: bootflash:/nexus-1000v-kickstart.4.2.1.SV1.5.2.bin
  kickstart compile time:  8/2/2012 23:00:00 [08/03/2012 08:33:37]
  system image file is:    bootflash:/nexus-1000v.4.2.1.SV1.5.2.bin
  system compile time:     8/2/2012 23:00:00 [08/03/2012 09:34:01]
Hardware
  cisco Nexus 1000V Chassis ("Virtual Supervisor Module")
  Intel(R) Xeon(R) CPU E5-2680 with 2075740 kB of memory.
  Processor Board ID T5056AA6C7E
   Device name: nexus01
  bootflash:    1557496 kB
Kernel uptime is 64 day(s), 13 hour(s), 26 minute(s), 20 second(s)
When i try to install the licence file ( previously put in bootflash from a tftp)  from the bootflash :
  nexus01# install license bootflash:N1KVFEAT2013.lic
Installing license .failed: No space left on device
Usage for bootflash://sup-local
  229548032 bytes used
1365327872 bytes free
1594875904 bytes total
So, apparently, is not running out of space.
There is a debug: direrctory  with a file axis.log, that consumes all the 2M :
ardv-nexus01# dir debug:
    2084864     Apr 05 11:52:17 2013  axis.log
       2858     Mar 21 14:40:28 2013  fm_error_critical.log.vdc_1.2753
Usage for debug://sup-local
    2097152 bytes used
          0 bytes free   *******
    2097152 bytes total
I try to remove the axis.log ( no debug is running), but the file is automatically re-created..
nexus01# sh debug
Debug level is set to Minor(1)
I try to install the license when the file was just 100k, but the result is the same...
Please , anyone can help me.....
fedcre
bug CSCug19319
License fails to install due to full isan partition
fedcre
bug CSCug19319
This is due to the apache logs filling up the /isan partition, which also acts as the temporary repository for a newly installed license.  Rebooting the VSM is the quick & easy way to resolve.  We're implementing a permanent fix to flush the logs on a regular basis in a future release.  This issue doesn't affect anything other than installation of licenses.  Once installed there is no affect from this bug.
Robert
thanks Robert,
yesterday I've installed the permanent license , performing a switchover of the active VSM on the standby one, because I've noticed that in the standby one the isan partition was used at around 57%. So I installed here the license file at it works.
After the switchover the new sup master was at 60% of use while the sup-standby at 57% , now (14 hours later) the active  is newly full...
Federica
I'd like to see what's in the apache logs that is filling up your system.
Would you be willing to do a quick webex so I can take a look at your system?  The plan would be to load the debug plugin and get a copy of the apache logs.  There's no impact to your environment.
If intereseted, please send me a private message with your email and I'll send over a webex invite.
Robert
