Questions on VLAN
ktwong
Reading thru the Nexus 1000V deployment guide, the doc recommended to separate vlan for control/packet and management interfaces on VSM. Let's say I chose to use vlan 10 for control and packet interfaces and excuted the following CLI in the N1KV:
vlan 10
  name N1K_Control/Packet
port-profile type vethernet N1K_Control/Packet
  vmware port-group
  switchport mode access
  switchport access vlan 10
  no shutdown
  system vlan 10
  state enabled
svs-domain
  domain id 999
  control vlan 10
  packet vlan 10
  svs mode L2
My question is:
Should VLAN 10 be created/defined in the upstream physical switch? OR when I exceute "vlan 10" CLI in N1KV, VLAN 10 would be created?
Ken
Response Signature
11 Replies 11
Robert Burns
Ken,
You need to create the VLANs on the upstream switches.  The 1000v doesn't yet support VTP, but if/when it does, it would only support transparent mode anyway.
If you don't create your Ctrl/Packet VLANs northbound, the upstream switch will NOT pass your system traffic.
Robert
Thanks, Robert.
So, when you ran the CLI "vlan 10" in N1KV, what does it do?
Ken
Response Signature
Hi Ken,
When you run "vlan 10" on the VSM, it is creating the vlan and programming it on the n1k. In a manner similar to what you would expect from an upstream switch, VLANs must be created/enabled on the switch before traffic will be allowed on that VLAN.
Sachin
Thanks for the explanation Sachin.
Now, I have modified all the eth and veth port-profiles inside N1KV to use the VLANs that were created in the upstream switch.
From vCenter (Home -> Inventory -> Networking), select the N1KV vDS and click on the hosts tab, the state column showed "Out of sync" for all hosts assocated with the N1KV. Also, looking at the eth and veth port-profiles inside vCenter, they were still using the old vlan before the changes.
How can I sync the configuration so that they aren't out of sync anymore?
Ken
Response Signature
From your VSM can you paste the output of:
show svs connection
Robert
Here you go.
N1K-VSM_1# show svs connections
connection vcenter:
    ip address: 172.19.246.183
    remote port: 88
    protocol: vmware-vim https
    certificate: default
    datacenter name: Core
    admin:
    max-ports: 8192
    DVS uuid: 55 73 27 50 ba ae 5b 51-17 03 79 2a b9 7e 5b b8
    config status: Enabled
    operational status: Connected
    sync status: Complete
    version: VMware vCenter Server 4.1.0 build-345043
Response Signature
ktwong
Oh, I also rebooted vCenter couple times.
Response Signature
So everything is good to go?
vCenter connection is sync'd up fine as per your output.
regards,
Robert
No. vCenter showed the hosts are disconnected.
Also, the eth and veth port-profiles in vCenter showed that they are using the old vlan info.
Does it take long time to sync?
Response Signature
Sync'ing should be very quick as soon as your VSM and VC can communicate.
I suspect your issue is that you're missing some "system vlan" config.
Can you paste your running config from your VSM and advise if you VSM is on the standard vSwitch or the 1000v DVS.
Robert
Hi Robert,
The VSM is Nexus 1000V. I remembered when I tried to change the VLAN and I need to do "no system vlan xx". The following question popup and I answered yes to proceed.
This will remove all system vlans from this port profile. Do you really want to proceed(yes/no)? [yes]
Could that cause the problem? If so, what is the correct to modify the system vlan?
Anyways, below is the running config of the N1KV:
Ken
_________________________
!Command: show running-config
!Time: Wed Aug 10 16:32:22 2011
version 4.2(1)SV1(4a)
no feature telnet
username admin password 5 $1$WJ5wg1U0$hjTXt7xIlxvS6iKVcsrAU.  role network-admin
banner motd #Nexus 1000v Switch#
ssh key rsa 2048
ip domain-lookup
ip domain-lookup
hostname N1K-VSM_1
vem 3
  host vmware id 414e3537-3241-3255-5839-333130323133
vem 4
  host vmware id 414e3537-3241-3255-5839-333130323135
vem 5
  host vmware id 33373531-3839-5553-4535-34364e363353
vem 6
  host vmware id 33373531-3839-5553-4535-34364e363456
snmp-server user admin network-admin auth md5 0x124607b9071f117b518792eda385db59 priv 0x124607b9071f117b518792eda385db59 localizedkey
vrf context management
  ip route 0.0.0.0/0 10.4.45.1
vlan 1
vlan 440
vlan 441
  name Mgmt
vlan 445
  name VM_Network_445
vlan 472
  name VM_Network_472
vlan 474
  name VM_Network_474
port-channel load-balance ethernet source-mac
port-profile default max-ports 32
port-profile type ethernet Unused_Or_Quarantine_Uplink
  vmware port-group
  shutdown
  description Port-group created for Nexus1000V internal usage. Do not use.
  state enabled
port-profile type vethernet Unused_Or_Quarantine_Veth
  vmware port-group
  shutdown
  state enabled
port-profile type ethernet ESX_Mgmt_Uplink
  vmware port-group
  switchport access vlan 441
  no shutdown
  system vlan 441
  state enabled
port-profile type ethernet VM_Uplink
  vmware port-group
  switchport mode trunk
  switchport trunk allowed vlan 440,445,472,474
  channel-group auto mode on mac-pinning
  no shutdown
  system vlan 440
  state enabled
port-profile type vethernet Mgmt
  vmware port-group
  no shutdown
  system vlan 441
  state enabled
  vmware port-group
  switchport access vlan 440
  no shutdown
  system vlan 440
  state enabled
port-profile type vethernet VM_Network_445
  vmware port-group
  switchport access vlan 445
  no shutdown
  state enabled
port-profile type vethernet VM_Network_472
  vmware port-group
  switchport access vlan 472
  no shutdown
  state enabled
port-profile type vethernet VM_Network_474
  vmware port-group
  switchport access vlan 474
  no shutdown
  state enabled
vdc N1K-VSM_1 id 1
  limit-resource vlan minimum 16 maximum 2049
  limit-resource monitor-session minimum 0 maximum 2
  limit-resource vrf minimum 16 maximum 8192
  limit-resource port-channel minimum 0 maximum 768
  limit-resource u4route-mem minimum 32 maximum 32
  limit-resource u6route-mem minimum 16 maximum 16
  limit-resource m4route-mem minimum 58 maximum 58
  limit-resource m6route-mem minimum 8 maximum 8
interface port-channel1
  inherit port-profile VM_Uplink
  vem 4
interface port-channel2
  vem 3
interface port-channel3
  vem 5
interface port-channel4
  vem 6
interface mgmt0
  ip address 10.4.45.99/24
interface Vethernet1
  inherit port-profile Mgmt
  description VMware VMkernel, vmk0
  vmware dvport 38 dvswitch uuid "55 73 27 50 ba ae 5b 51-17 03 79 2a b9 7e 5b b8"
  vmware vm mac 0023.7DE5.37F6
interface Vethernet2
  vmware dvport 37 dvswitch uuid "55 73 27 50 ba ae 5b 51-17 03 79 2a b9 7e 5b b8"
  vmware vm mac 0023.7DE5.3802
interface Vethernet3
  vmware dvport 36 dvswitch uuid "55 73 27 50 ba ae 5b 51-17 03 79 2a b9 7e 5b b8"
  vmware vm mac 0014.C2C0.4E43
interface Vethernet4
  vmware dvport 39 dvswitch uuid "55 73 27 50 ba ae 5b 51-17 03 79 2a b9 7e 5b b8"
  vmware vm mac 0014.C2C1.0BAD
interface Vethernet5
  inherit port-profile VM_Network_445
  description Win2003, Network Adapter 1
  vmware dvport 576 dvswitch uuid "55 73 27 50 ba ae 5b 51-17 03 79 2a b9 7e 5b b8"
  vmware vm mac 0050.56A7.0000
interface Ethernet3/1
  inherit port-profile ESX_Mgmt_Uplink
interface Ethernet3/2
interface Ethernet4/1
interface Ethernet4/2
interface Ethernet5/1
interface Ethernet5/2
interface Ethernet6/1
interface Ethernet6/2
interface control0
line console
boot kickstart bootflash:/nexus-1000v-kickstart-mz.4.2.1.SV1.4a.bin sup-1
boot system bootflash:/nexus-1000v-mz.4.2.1.SV1.4a.bin sup-1
boot kickstart bootflash:/nexus-1000v-kickstart-mz.4.2.1.SV1.4a.bin sup-2
boot system bootflash:/nexus-1000v-mz.4.2.1.SV1.4a.bin sup-2
svs-domain
  domain id 999
  control vlan 440
  packet vlan 440
  svs mode L2
svs connection vcenter
  protocol vmware-vim
  remote ip address 172.19.246.183 port 88
  vmware dvs uuid "55 73 27 50 ba ae 5b 51-17 03 79 2a b9 7e 5b b8" datacenter-name Core
  max-ports 8192
  connect
vsn type vsg global
  tcp state-checks
vnm-policy-agent
  registration-ip 0.0.0.0
  shared-secret **********
  log-level
Response Signature
