SFP compatibility
dan-enculescu
Hi guys,
I have a wondering related by the compatibility of a sfp model with two models of Nexus 9k (N9K-C93180YC-FX3 and N9K-C93180YC-FX3H). I have searched the matrixes of compatibility, but the problem is that the output of the show interface transceiver is:
ro-pcdc93-r305-ISS-AGG1-N9K# sho int eth1/19 transceiver
Ethernet1/19
transceiver is present
type is 1000base-T
name is CISCO-AVAGO
part number is ABCU-5710RZ-CS5
revision is B2
serial number is AGM19234CBA
nominal bitrate is 1300 MBit/sec
Link length supported for copper is 100 m
cisco id is 3
cisco extended id number is 4
and nothing else.
The output of show interface transceiver sprom is:
ro-pcdc93-r305-ISS-AGG1-N9K# sho int eth1/19 transceiver sprom
Ethernet1/19
type is 1000base-T
name is CISCO-AVAGO
revision is B2
cisco id is 3
Identifier : 0x03 (SFP)
Ext_Identifier :0x04
Connector : 0x00 (Unknown)
Infiniband Compliance Code : 0x00 (None)
Sonet Compliance Code : 0x0000
Gigabit Ethernet Compliance Code: 0x08 (1000Base-T)
Encoding : 0x01 (8B/10B)
BR_Nominal : 0x0d [1300]
Reserved1 : 0x00
Length_9u_1 : 0x00 0 KM
Length_9u_2 : 0x00 0 Meters
Length_50u : 0x00 0 Meters
Length_60u : 0x00 0 Meters
Length_Copper : 0x64 100 Meters
Reserved2 : 0x00
Vendor Name : CISCO-AVAGO
Reserved3 : 0x01
Vendor OUI : 0x00176a
Vendor Part No : ABCU-5710RZ-CS5
Vendor Revision : B2
Reserved4 : 0x410cc1
Check Code ID : 0x4a (OK)
Options : 0x0010
BR Max : 0x00
BR Min : 0x00
Vendor Serial No : AGM19234CBA
Date Code : 150606
Diagnostic Monitoring Type : 0x00
enchancedOptions : 0x00
SFF8472Compliance : 0x00
Check Code EXT : 0xc0 (OK)
Vendor Specific ID Data : 0x00000631370a2da2eb159ef60159d678
: 0xf91cd9000000000000000000828cd81b
From my oppinion is somehow a model of GLC-TE,  but I am not sure cause cisco product id is missing.
I need to be sure about if it is or not compatible with the mentioned models of nexus 9k. Have anyone a solution for me ?
Thanks in advance
Dan Enculescu
AshSe
Hello @dan-enculescu
The transceiver you have (ABCU-5710RZ-CS5) is likely a 1000Base-T module similar to the Cisco GLC-TE. If it is a genuine Cisco module, it should be compatible with the N9K-C93180YC-FX3and N9K-C93180YC-FX3H models, provided the correct NX-OS version is installed. However, the lack of a Cisco product ID raises concerns about its authenticity or compatibility. To ensure proper operation, verify the transceiver against the Cisco Transceiver Compatibility Matrix and test it in your environment.
Hope This Helps!!!
AshSe
Forum Tips:
  1. Insert photos/images inline - don't attach.
  2. Always mark helpful and correct answers, it helps others find what they need.
  3. For a prompt reply, kindly tag @name. An email will be automatically sent to the member.
