SFP not inserted
beta_admin66
Hello together,
I want to make a vpc from Cisco Nexus 5020 with Nexus 5010. I use a Cisco Twinax cable SFP-H10GB-CU3M.
If I have connected the twinax cable to the switch port, the output shows: SFP not inserted. show int status:
sfpAbsent.
Which SFP must be used for this port? Fet10G The output shows: SFP not inserted
Thank you very much.
Sergiu.Daniluk
Hi @beta_admin66
You cannot configure a vpc domain with two different Nexus models. The Nexus platforms needs to be identical.
Stay safe,
Sergiu
