SNMP multiple alerts detected : Interface Down - null (null)
Any one have any idea about below alert getting, which is showing as critical. Please let me know any one have the fix for this issue as its getting on my nexus 7k device.
Critical 0 <Date> <Time> <hostname> Interface Down - null (null)
waiting for the solution.
pecify the source interface for informs and traps if the management VRF instance is not being used. This allows security devices such as firewalls to identify the source of the SNMP packet. If the source interface or IP address is not specified the primary IP address on the originating (outbound) interface is selected. The inform feature only applies to SNMP v2c and v3. You can configure the source interface globally for all SNMP hosts or per SNMP host.
Global Configuration:
 n7000(config)# snmp source-interface informs loopback0
 n7000(config)# snmp source-interface traps loopback0
Per Server Configuration:
 n7000(config)# snmp-server host a.a.a.a source-interface loopback0
