SNMPv3 Configuration Sample for Cisco Nexus9K switch
SaintEvn
Can you guys please help me with working SNMPv3 configuration on Cisco Nexus N9K switch ?
I've read the following link from cisco but still didn't get how to configure it properly.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/system_management/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_System_Management_Configuration_Guide/sm_9snmp.html#con_1059321
Sergiu.Daniluk
The syntax is like this:
 snmp-server user name [auth {md5 | sha} passphrase [auto] [priv [aes-128] passphrase] [engineID id] [localizedkey]]
Below is a config example:
N9K-1# conf t
Enter configuration commands, one per line.  End with CNTL/Z.
N9K-1(config)# snmp-server user MySNMPuser ?
  WORD   Group name (ignored for notif target user) (Max Size 28)
  auth   Authentication parameters for the user
N9K-1(config)# snmp-server user MySNMPuser network-admin auth ?
  md5  Use HMAC MD5 algorithm for authentication
  sha  Use HMAC SHA algorithm for authentication
N9K-1(config)# snmp-server user MySNMPuser network-admin auth md5 ?
  WORD  Authentication password for user (Max Size 130)
N9K-1(config)# snmp-server user MySNMPuser network-admin auth md5 AuthPass ?
  engineID      EngineID for configuring notif target user (for V3 informs)
  localizedkey  Specifies whether the passwords are in localized key format
  priv          Encryption parameters for the user
N9K-1(config)# snmp-server user MySNMPuser network-admin auth md5 AuthPass priv ?
  WORD     Privacy password for user (Max Size 130)
  aes-128  Use 128-bit AES algorithm for privacy
N9K-1(config)# snmp-server user MySNMPuser network-admin auth md5 AuthPass priv aes-128 ?
N9K-1(config)# snmp-server user MySNMPuser network-admin auth md5 AuthPass priv aes-128 PrivacyPass
DC-Team-N9K-2(config)# show snmp user
______________________________________________________________
                  SNMP USERS
User                Auth  Priv(enforce) Groups              acl_filter
____                ____  _____________ ______              __________
admin               md5   des(no)       network-admin
MySNMPuser          md5   aes-128(no)   network-admin
 NOTIFICATION TARGET USERS (configured  for sending V3 Inform)
User                          Auth  Priv
____                          ____  ____
DC-Team-N9K-2(config)# snmp-server globalEnforcePriv
                  SNMP USERS [global privacy flag enabled]
admin               md5   des(yes)      network-admin
MySNMPuser          md5   aes-128(yes)  network-admin
User                          Auth  Priv
____                          ____  ____
There are a lot of other possible configs like the destination SNMP server, what traps to send, on which VRFs, what is the source of traps and so on, but all these are are exemplified at the end of the document you pointed out.
Stay safe,
Sergiu
