Total Power consumption of Catalyst 9410 at full config.
edmont
Hi, I just need to know the total consumption of the Catalyst 9410 with full config.
This question is due each 3200 W AC power supplies states 16A but it don´t clarify if this is per PS or is a total per entry SW.
Thank you guys.
julian.bendix
Level 3
Level 3
Hi!
Why do you want to know how many Amps will me used?
Everything should be clarified in the Data Sheet, Power Consumption (in Watts) listed per PSU:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9400-series-switches/nb-06-cat9400-ser-data-sheet-cte-en.html
How many Amps depending on how much Voltage is supplied, is also listed.
Hope that helps
Juls
julian.bendix
Level 3
Level 3
Hi!
Hope that helps
Juls
I need to be aware of the consumption in order to prepare the power infrastructure in advance.
But in the datasheet they say 16A per PS no matter if is 100 or 200Vac, so if we will have 8 PS, I need to reserve 16A in total or 16*8A???
