09-29-2020 06:09 AM
I'm in the process of upgrading to the latest EPLD and I came to this instruction that states to use this command if you don't need to upgrade the bios "boot nxos bootflash:n9000-dk9.9.3.5.bin." I don't have this file in bootflash and I'm not sure where I'd get it. Can someone explain if this command?
Thank you,
Steve Schubert
Solved! Go to Solution.
09-29-2020 12:27 PM
Hi Steve!
Most Nexus 9000 switches are equipped with two FPGAs - the IO FPGA, and the MI FPGA. Each FPGA has two memory regions to store its firmware - the Primary region, and the Golden region. The idea behind this is that in the rare event that one of the regions is corrupted, the FPGA would continue to function by booting firmware from the other region.
The install all epld command upgrades the Primary region of both FPGAs. After reloading, the switch will boot from the Golden region so that NX-OS can verify the Primary region was not corrupted during the upgrade. As a result, the output of show version module 1 epld will show the MI FPGA and IO FPGA versions of the Golden region, not the Primary region that was just updated. I performed an EPLD upgrade on a Nexus 93180YC-FX in my lab environment to demonstrate this:
N9K# show module Mod Ports Module-Type Model Status --- ----- ------------------------------------- --------------------- --------- 1 54 48x10/25G/32G + 6x40/100G Ethernet/FC N9K-C93180YC-FX active * Mod Sw Hw Slot --- ----------------------- ------ ---- 1 9.3(5) 1.1 NA N9K# show version module 1 epld EPLD Device Version --------------------------------------- MI FPGA 0x10 IO FPGA 0x17 N9K# install epld bootflash:n9000-epld.9.3.5.img module all Digital signature verification is successful Compatibility check: Module Type Upgradable Impact Reason ------ ----------------- ---------- ---------- ------ 1 SUP Yes disruptive Module Upgradable Retrieving EPLD versions.... Please wait. Images will be upgraded according to following table: Module Type EPLD Running-Version New-Version Upg-Required ------ ---- ------------- --------------- ----------- ------------ 1 SUP MI FPGA 0x10 0x10 No 1 SUP IO FPGA 0x17 0x22 Yes The above modules require upgrade. The switch will be reloaded at the end of the upgrade Do you want to continue (y/n) ? [n] y Proceeding to upgrade Modules. Starting Module 1 EPLD Upgrade Module 1 : IO FPGA [Programming] : 100.00% ( 64 of 64 sectors) Module 1 EPLD upgrade is successful. Module Type Upgrade-Result ------ ------------------ -------------- 1 SUP Success Module 1 EPLD upgrade is successful. Reseting Active SUP (Module 1) FPGAs. Please wait... <snip, switch reloaded> N9K# show version module 1 epld EPLD Device Version --------------------------------------- MI FPGA 0x10 IO FPGA 0x17 N9K# show logging logfile | include FPGA 2020 Sep 29 17:07:21 N9K %CARDCLIENT-2-FPGA_BOOT_GOLDEN: IOFPGA booted from Golden 2020 Sep 29 17:07:21 N9K %CARDCLIENT-2-FPGA_BOOT_GOLDEN: MIFPGA booted from Golden 2020 Sep 29 17:07:21 N9K %CARDCLIENT-5-MOD_BOOT_GOLDEN: Module 1 IOFPGA booted from Golden 2020 Sep 29 17:07:21 N9K %CARDCLIENT-5-MOD_BOOT_GOLDEN: Module 1 MIFPGA booted from Golden
In order to upgrade the Golden region, you will need to use the install epld bootflash:n9000-epld.9.3.5.img module all golden command to upgrade the Golden region as well. This will cause the switch to reload once more, after which it will boot from the Primary region with the upgraded EPLD versions as expected.
N9K# install epld bootflash:n9000-epld.9.3.5.img module all golden Digital signature verification is successful Compatibility check: Module Type Upgradable Impact Reason ------ ----------------- ---------- ---------- ------ 1 SUP Yes disruptive Module Upgradable Retrieving EPLD versions.... Please wait. Images will be upgraded according to following table: Module Type EPLD Running-Version New-Version Upg-Required ------ ---- ------------- --------------- ----------- ------------ 1 SUP MI FPGA 0x10 0x10 Yes 1 SUP IO FPGA 0x17 0x22 Yes The above modules require upgrade. The switch will be reloaded at the end of the upgrade Do you want to continue (y/n) ? [n] y Proceeding to upgrade Modules. Starting Module 1 EPLD Upgrade Module 1 : MI FPGA [Programming] : 100.00% ( 64 of 64 sectors) Module 1 : IO FPGA [Programming] : 100.00% ( 64 of 64 sectors) Module 1 EPLD upgrade is successful. Module Type Upgrade-Result ------ ------------------ -------------- 1 SUP Success Module 1 EPLD upgrade is successful. Reseting Active SUP (Module 1) FPGAs. Please wait... <snip, switch reloaded> N9K# show version module 1 epld EPLD Device Version --------------------------------------- MI FPGA 0x10 IO FPGA 0x22 N9K# show logging logfile | include FPGA 2020 Sep 29 19:11:47 N9K %CARDCLIENT-2-FPGA_BOOT_PRIMARY: IOFPGA booted from Primary 2020 Sep 29 19:11:47 N9K %CARDCLIENT-2-FPGA_BOOT_PRIMARY: MIFPGA booted from Primary 2020 Sep 29 19:11:47 N9K %CARDCLIENT-5-MOD_BOOT_PRIMARY: Module 1 IOFPGA booted from Primary 2020 Sep 29 19:11:47 N9K %CARDCLIENT-5-MOD_BOOT_PRIMARY: Module 1 MIFPGA booted from Primary
As a side note, I filed documentation bug CSCvv91381 (which may not yet be public-facing to you) this morning to update this documentation across the board to be more accurate and centralized. I will make sure that the procedure for upgrading the Golden region is also included as part of this update.
I hope this helps - thank you!
-Christopher
09-29-2020 07:02 AM - edited 09-29-2020 07:04 AM
Hi Steve!
This appears to be an error in our documentation. The command should be boot nxos bootflash:nxos.9.3.5.bin, which is the NX-OS binary image file for software release 9.3(5) that is available for download from Cisco's Software Download website. I will work internally to have this documentation corrected across all NX-OS FPGA/EPLD release notes.
Assuming that you are already running the NX-OS software release that you want to upgrade EPLD to (e.g. NX-OS software release 9.3(5)), the only command you need to run is install all epld bootflash:n9000-epld.9.3.5.img module all. Note that this command is disruptive, as the switch will reload to load the new EPLD images. The majority of the commands in the documented procedure appear to be unnecessary - I will work internally to have this corrected as well.
-Christopher
09-29-2020 07:17 AM
Hi Christopher,
I thought this may be the case. However, the one thing that confused me was after I performed the upgrade and then ran the two commands to verify it worked. It appeared that the upgrade was successful with this commmand, "show install epld status" but unsuccessful with this command, "show version module 1 epld"
Am I missing anything?
N9236C-B# show version module 1 epld
EPLD Device Version
MI FPGA 0x9
IO FPGA 0x15
N9236C-B# show install epld status
1) Module 1 upgraded on Mon Sep 28 22:11:03 2020 (179390 us)
EPLD Install Image: EPLD image file 9.3.5. built on Mon Jul 20 22:37:31 2020
Status: EPLD Upgrade was Successful
EPLD Curr Ver Old Ver
IO FPGA 0x17 0x16
2) Module 1 upgraded on Mon Sep 28 22:11:03 2020 (179326 us)
IO FPGA 0x17 0x16
3) Module 1 upgraded on Wed Apr 24 22:19:29 2019 ( 60873 us)
EPLD Install Image: EPLD image file 9.2.3.I9.1. built on Sun Feb 17 04:25:02 2019
IO FPGA 0x16 0x15
4) Module 1 upgraded on Wed Apr 24 22:19:29 2019 ( 60840 us)
IO FPGA 0x16 0x15
09-29-2020 12:27 PM
Hi Steve!
-Christopher
