vCenter reinstall, recover VEM?
mizzou_robman
Is there a guide for recovering the VEM if you have to reinstall vCenter 4.0?
The VSM (virtual appliances) seem to be running.
Robert Burns
Not that I'm aware of.  If you're restoring your vCenter DB, you should be fine assuming the vCenter is given the same hostname & IP as previously.
If you're building a new VC (with freash database) and just connecting your vSphere hosts to it, you'll need to re-register the VSM's extension key, and re-add each host to the DVS.
I'll check if I can find you anything more helpful.
Questions:
1. Are you restoring the VC server and/or the Database from backup?
2. Which version of 1000v & vSphere Build are you running?
Robert
1. Not restoring from backup
2. vCenter 4.0.0 build 208111, ESXi 4.0.0 bld 261974, Nexus 1kv VSM 1.3
I also have a problem with a new instance of vCenter and adding an already configured VSM to it. That's my szenario:
I have to install a new vCenter instance. VSM connected to it without any problems: same key fingerprint, new UUID. While I tried to import an ESX host, I always got the message that the portsets already exists and the CreateDVS command has failed. And that's the problem: I don't want to create a new DVS, I have to use the existing one, because it is in productive use. And therefore my question: how to add a configured VEM/VSM to a new vCenter instance without interrupting productive environment?
We use vCenter/ESX 4.1 and VSM/VEM 1.3(a).
Thanks a lot in advance for all your answers ;-)
