Good Morning
We want connect two DC using BGP EVPN solution having VXLAN feature in each site. We have doubts about if is possible extend VNI over a network with this approach :
EVPN-VXLAN <-> EVPN-MPLS <-> EVPN-VXLAN
We have found information with Juniper as solution (attached topology) but Cisco.
Is this solution feasible with Cisco ? Are there any documents to confirm it?
Thank you very much !!
Best Regards,
Solved! Go to Solution.
The options available on Nexus switches are:
If what you are looking for is simply interconnecting 2x DCs then you can consider VXLAN EVPN MultiSite, so your connectivity would be underlay agnostic:
Stay safe,
Sergiu
Stay safe,
Sergiu
Hi Sergiu,
This is fantastic. Is very helpful for me.
Thank you very much,
Best Regards,
