We need to create a Breakout port from Nexus switch to ASR Router
arakeshr
Hi Guys,
We have a new implementation.
we need to connect Breakout port from Cisco Nexus SW to ASR Router,
1.Cisco nexus switch has a 100 G port and we using a breakout port to connect ASR Router ( to replace the existing 100G port with 4x10G port break-out cable).
2.We have a100 Gig Ports for Nexus switch side and 10 G ports for ASR Router side.
Those are point to point links.
3.Please tell how to i configure this ports from nexus to ASR Router. Please help the configuration details, how can I proceed.
4.We advertised the VRF and BGP (Present existing config)
Rakesh
ss1
What's your physical topology (the module on the Nexus and the type of the cord) ?
Those things are normally done by MPO to 4x LC/UPC breakout patch cords and a QSFP-40G-PLRL4 on the Nexus side. Then you enable breakout mode on the respective port.
Hi ,Thanks for your replay.
we have a new requirement from existing topology
1.we need to configure a Breakout port to ASR Router from Cisco nexus switch
2.Nexus having 100G port bandwidth and ASR having 10G Bandwidth.
3.We bought a 4x10G port break-out cable
4.before we have a point to point link between the Nexus switch to ASR router
5.we need to  configure breakout port will be on asr router side
6.interface Ethernet1/49
description * Connected to_9906_1 PORT-Ten0/0/0/2 *
vrf member TELCEL
bfd interval 300 min_rx 300 multiplier 3
no bfd ipv4 echo
ip address 10.27.4.2/30
no shutdown
We having a present topology Configuration on a port level
new requirement like below:
please help on this,how to create.
Rakesh
