I trying to create the phone which device type is CISCO 7945. It needs MacID as input which is 12 digit number.
I trying to invoke the CISCO AXL API 10.5 in C# and I trying same in SOAP UI to achieve task.but,it fails any helps on this much appreciated.. (refer screen shot)These are the mandatory fields which need to configure while creating the phone in CUCM GUI and its created successfully and now i'm passing in same set of input in SOAP UI which is not working
INPUT
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/10.5">
<soapenv:Header/>
<soapenv:Body>
<ns:addPhone sequence="?">
<phone ctiid="?">
<name>123567890123</name>
<!--Optional:-->
<description>12345098791234</description>
<phoneTemplateName uuid="?">Standard 7945 SCCP</phoneTemplateName>
<devicePoolName uuid="?">ANIL</devicePoolName>
<ownerUserName uuid="?">1011</ownerUserName>
<securityProfileName uuid="?">Cisco 7945 - Standard SCCP Non-Secure Profile</securityProfileName>
</phone>
</ns:addPhone>
</soapenv:Body>
</soapenv:Envelope>
ERROR
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
<soapenv:Body>
<soapenv:Fault>
<faultcode>soapenv:Client</faultcode>
<faultstring>A character to numeric conversion process failed</faultstring>
<detail>
<axlError>
<axlcode>-1213</axlcode>
<axlmessage>A character to numeric conversion process failed</axlmessage>
<request>addPhone</request>
</axlError>
</detail>
</soapenv:Fault>
</soapenv:Body>
</soapenv:Envelope>
