A built-in element encountered an exception of type com.audium.server.Audium.Exception
HaiKLe8577
We used a built-in Action-Element to retrieve encrypted data from a internal web-page. We kept encounter an exception that elute us to think the ActionResponse-message is incorrect.  The exception is:
Caused by: com.audium.server.AudiumException: Execution failed for action element 'Encrypt_SSN' with the following error:
at com.audium.server.controller.HttpActionElement.parseResponseDoc(HttpActionElement.java:142)
at com.audium.server.controller.HttpActionElement.doAction(HttpActionElement.java:116)
at com.audium.server.voiceElement.ActionElementBase.service(ActionElementBase.java:390)
... 21 more
The returned XML message from the web page is:
<?xml version='1.0' encoding='UTF-8'?>
<result>
  <status>success</status>
  <error></error>
  <new_data>
   <session name="Encrypt_SSN">EAAQz++B7QSG3fD+OqtO+blcrA==</session>
  </new_data>
  <set_uid></set_uid>
  <set_flag></set_flag>
  <log>
   <custom name="Message">Encrypted SSN = EAAQz++B7QSG3fD+OqtO+blcrA==</custom>
  </log>
  <set_default_path></set_default_path>
  <set_maintainer></set_maintainer>
  <set_timeout></set_timeout>
  <set_main_doc_content>
   <language>en-US</language>
   <encoding>UTF-8</encoding>
  </set_main_doc_content>
</result>
We validated the XML-message and it seemed to conform to the ActionResponse.DTD.  Have you seen this issue before and how did you resolved it?
Many thanks in advance.
-Hai Le
Geevarghese Cheria
Did you had chance to refer the following urls
  I would also request to post if there is any further questions related to the topic under -Customer Voice Portal community.
Thanks and Regards,
Geevarghese
