AXL getLicensedUser
Josh Gross
Frequent Visitor
Frequent Visitor
Has anyone been able to use the getLicensedUser method in AXL. I'm trying it with version 11 and receive:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
   <soapenv:Body>
      <soapenv:Fault>
         <faultcode>soapenv:Client</faultcode>
         <faultstring>Could not open database table (database.licenseutilization).</faultstring>
         <detail>
            <axlError>
               <axlcode>-242</axlcode>
               <axlmessage>Could not open database table (database.licenseutilization).</axlmessage>
               <request>getLicensedUser</request>
            </axlError>
         </detail>
      </soapenv:Fault>
   </soapenv:Body>
</soapenv:Envelope>
5 Replies 5
davidn#
Hi Josh,
Can you share the AXL request? Thanks.
David
Geevarghese Cheria
Hi Josh,
   Request to post your query under AXL community so that it will help more experts to view the question. For relative information regarding License request to have a look in the following url - CUCM - AXL API : Getting License Info
Thanks and Regards,
Geevarghese
Thank you. I will do that.
sdoddaga
Hi All,
Wanted to know as to how the above issue got resolved, customer is hitting the same issue on 11.5.1 cucm
Thanks in advance.
Sowmya
Did you by chance get an answer on the resolution of this problem?
