C9800 using netconf
josecarvalho
Frequent Visitor
Frequent Visitor
I want to use netconf to get status from C9800. module: Cisco-IOS-XE-wireless-access-point-oper +--ro access-point-oper-data +--ro ap-radio-audit-info* [wtp-mac radio-slot-id]
Torbjørn
Can you describe what you are looking for more specifically? Are you looking to enable netconf on the 9800? Are you asking how to fetch this with a specific tool(python/go/others)?
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Torbjørn
Here is an example of the Netconf RPC message that you can send, this is just a high-level example, and you may need to adjust the code to fit your specific requirements and the capabilities of your C9800 device. Additionally, ensure that you handle any errors or exceptions that may occur during the NETCONF communication.
<rpc message-id="1" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <get>
    <filter type="subtree">
      <cisco-ios-xe-wireless-access-point-oper xmlns="http://cisco.com/ns/yang/Cisco-IOS-XE-wireless-access-point-oper">
        <access-point-oper-data/>
      </cisco-ios-xe-wireless-access-point-oper>
    </filter>
  </get>
</rpc>
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Ruben Cocheno
@josecarvalho
try this
ap_radio_audit_info_filter  =  etree . Element ( " {urn:ietf:params:xml:ns:netconf:base:1.0} filter" ,  type = "xpath" ,  nsmap  = { None : 'urn:cisco:com:ns:yang:Cisco-IOS-XE-wireless-access-point-oper' },  select  =  "/access-point-oper-data/ap-radio-audit-info[wtp-mac='xx:xx:xx:xx:xx:xx'][radio-slot-id='1']" )
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
