Cisco Modelling lab integration with Monitoring Tool
nikaitagahi
 Hi , We have installed CML for network simulation but we want to do some set up for monitoring of topology created in CML using Nagios or solarwinds. Is it possible to monitor CML devices using any monitoring tool?
Ruben Cocheno
@nikaitagahi
Yes
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
balaji.bandi
If the CML have external connetivity you can install NMS and monitor the devices inside CML
or you can use ubuntu as node inside CML
https://developer.cisco.com/docs/modeling-labs/ubuntu/#ubuntu
BB
You could also do this with MDT using a TIG/ELK stack
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Ruben Cocheno
@nikaitagahi
Yes
