Configure Cisco switch with C sharp application
PawelMakowski13726
Community Member
Hi all, I'm trying to write the C sharp application to configure Cisco Switch.
I'm using Renci.SshNet library. The problem whe I'm trying to enter to CONFIG mode. The next command is being not recognized. Any idea?
Regard
Paweł
Dennis Mink
Can you share the code you have and a screenshot of the actual error. Thx
Please remember to rate useful posts, by clicking on the stars below.
Here's asynchronous version:
using (var sshclient = new SshClient(sutIP, sutUsername, sutPassword))
    sshclient.Connect();
    var cmd = sshclient.CreateCommand("configure terminal");
    var asynch = cmd.BeginExecute();
    while (!asynch.IsCompleted)
        // Waiting for command to complete...
       System.Threading.Thread.Sleep(2000);
    var result = cmd.EndExecute(asynch);
    sshclient.CreateCommand("interface Ethernet 1/1");
    sshclient.CreateCommand("speed 10000");
    sshclient.CreateCommand("end");
    sshclient.CreateCommand("show run");
    sshclient.Disconnect();
And here not:
List<string> commandSet = new List<string>();
commandSet.Add("configure terminal");
commandSet.Add("interface Ethernet 1/1");
commandSet.Add("speed 10000");
commandSet.Add("end");
commandSet.Add("copy running-config startup-config");
commandSet.Add("show running-config");
RunListOfSSHCommands(sutIP, sutUsername, sutPassword, commandSet);
public static void RunListOfSSHCommands(string sutIP, string sutUsername, string sutPassword, List<string> commandSet)
    using (SshClient ssh = new SshClient(sutIP, sutUsername, sutPassword))
        ssh.Connect();
        foreach (string command in commandSet)
             var result = ssh.RunCommand(command);
             Console.WriteLine(result.Result.ToString());
        ssh.Disconnect();
The error is attached.
