ios xe yang restconf default interface commands
Austin Marsh
Frequent Visitor
Frequent Visitor
I see ways to setup an interface via the ios-xe api, but it doesn't look like there is a way to set an interface back to defaults.  I want to do the equivalent of "default interface g0/0/1".  It seems like there are ways if I choose to use the cli module for python or ssh with netconf to accomplish this.  I'm trying to do this on a catalyst 9k switches.
troyperkins
Edit:  Sorry, I read netconf instead of restconf.  I haven't had much luck with restconf but if you are willing to try netconf this will probably work.
Take a look at Cisco-IOS-XE-rpc as I believe this is what you are looking for (haven't tried it yet, just looked it up):
rpc default {
    description
      "Set a command to its defaults";
    input {
      choice default-choice {
        mandatory true;
        case interface-case {
          leaf interface {
            description
	      "Select an interface to configure";
            type string {
              pattern "[A-Za-z]([\w/.-]+)";
    output {
      uses cisco-xe-rpc-output;
Yea not quite what I'm looking for, thanks though.
