Control Hub version and any integration documents
globantt
   We have to build an autonomous administrator using the Control Hub API.  Can you provide the version of Control Hub API and any integration documents ?
Ruben Cocheno
@globantt
Need more details to help you…
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
@globantt i would be happy to be wrong here (often happens!) i dont think there is a single comprehensive "integration document" for the Control Hub API. These resources should help, first check the Webex Control Hub Admin API, this is likely the resource you'll be referencing the most and It provides an overview, authentication methods, specific API calls, and references to error codes. https://developer.webex.com/docs/admin  I would then check the API Changelog, this page details recent updates and changes made to the Control Hub API. Staying up-to-date on these changes is crucial for maintaining a functional autonomous administrator. https://developer.webex.com/docs/api/changelog
For Platform Specifics, see the StreamSets Control Hub API, for if you are using StreamSets, they provide their own documentation for the Control Hub API processor, including authentication methods and specific considerations for their platform. https://docs.streamsets.com/platform-datacollector/latest/datacollector/UserGuide/Processors/ControlHubAPI.html
Depending on your development environment or chosen platform, there might be additional integration guides available for you also.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
