CUCM Integration
comeno.rossi
Hi guys,
I would like to integrate CUCM 8.6 with my own web application, basically an authenticated user should make a call from the webpage.
So what is the preferential way to do this?
I see some discussions about TAPI/JTAPI/CTIOS but i'm not sure that can be used with a CUCM and I wonder if there are any REST api.
The application backend is written in .NET.
Thanks in advance.
smupadhy
Can you elaborate on what you are trying to achieve?
This site will give you a snapshot of the APIs - Cisco DevNet: Collaboration Developer Center
Also, the End-of-Life has been announced for CUCM 8.6, and it is past the "end of SW Maintenance date". If you are developing a customer application, we would encourage you to move to the newer releases like 10.5 or 11.0.
