Data not being sent at 10Gbps on Cisco Nexus SmartNIC K3P-S
Hey
I have been testing the trigger example provided with exanic x25 FDK. The trigger example along with the software application provided by exanic-software exasock-tcp-responder-example is working fine at 1Gbps data rate.
I have developed the FDK using VARIANT=full_multirate which supports 1/10G data rates. When I'm trying to run the same firmware at 10G speed, somehow the x25 is not able to send out the data. The data can be properly seen at tx_xx_net but the the tcp server the application is connected does not receive any data.
When 10G speed is being used for testing, the switch is connected to the NIC using 1m cisco SFP-H10-CU1M 10G SFP+ twinax cable. Attaching the code snip just fro reference.
If anybody can suggest where things are going wrong, it would be very helpful.
0 Replies 0
