ExecuteCCMSQLStatement SOAP Request via Python
matthar2
Community Member
Hey guys!,
I have been hacking away at getting a SOAP request to work with the ExecuteCCMSQLStatement service call but continuously I am facing the following error:
Traceback (most recent call last):
  File "get_phone_stats.py", line 95, in <module>
    get_sql(data)
  File "get_phone_stats.py", line 35, in get_sql
    retval = client.service.ExecuteCCMSQLStatement("", {'Name':'Any'})
  File "/usr/lib/python2.6/site-packages/suds/client.py", line 542, in __call__
    return client.invoke(args, kwargs)
  File "/usr/lib/python2.6/site-packages/suds/client.py", line 602, in invoke
    result = self.send(soapenv)
  File "/usr/lib/python2.6/site-packages/suds/client.py", line 649, in send
    result = self.failed(binding, e)
  File "/usr/lib/python2.6/site-packages/suds/client.py", line 702, in failed
    r, p = binding.get_fault(reply)
  File "/usr/lib/python2.6/site-packages/suds/bindings/binding.py", line 265, in get_fault
    raise WebFault(p, faultroot)
suds.WebFault: Server raised fault: 'java.lang.ArrayStoreException'
Below is the code snippet I am currently using:
def get_sql(data):
   Connect to sql soap webservice
   to get device pool per device
   for i in data:
     uri = 'https://' + i[0] + ':8443/realtimeservice/services/RisPort?wsdl'
     imp = Import('http://schemas.xmlsoap.org/soap/encoding/')
     doctor = ImportDoctor(imp)
     client = Client(url=uri, transport=t, doctor=doctor)
     print retval
And I've narrowed down the problem to:
Any help on how to pass arguments to ExecuteCCMSQLStatement would be appreciated:
Here is what the WSDL defines:
ExecuteCCMSQLStatement(xs:string ExecuteSQLInputData, ArrayOfGetColumns GetColumns, )
Thanks again!
Geevarghese Cheria
Hi Matthew,
   Apologies for the delay in responding to you. If the issue is not yet resolved request to post your question under UC Manager Serviceability community. Also iam not sure you can try AXL also. Found a relative url -python client for AXL
Thanks and Regards,
Geevarghese
