How to install JTAPI in dockerfile as per instructions?
rkrtufvv
instructions at this link: https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/jtapi_dev/12_5_1/cucm_b_cisco-unified-jtapi-developers-guide-1251/cucm_b_cisco-unified-jtapi-developers-guide-1251_chapter_011.html#CUCM_TK_VE5899B2_00
I ran install64.sh. Moved to the installation site. And as I understand it, the jtprefs.bat file launches the jtapi.ini graphical configuration utility, after which the .jtapiver.ini file should appear? When I run it, nothing gets executed or waits. Can I just skip this step?
How can I even set this in the Dockerfile?
Ruben Cocheno
@rkrtufvv
Has this been resolved? Do you still need help?
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
