I want the Beacon LED to light up at boot up.
claudemichel
 As the title says, Could you please let me know if it is possible to make the Beacon Blue LED light up at startup? I would especially like to know how to do this for Catalyst9000 and 4500.
Ruben Cocheno
@claudemichel
I don’t think is possible
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
You would need to check documents to see if this possible, i saw on this on other models
To turn a blue beacon on in cli
Switch(config)#
hw-module beacon on switch 1
To turn a blue beacon off in cli
Switch(config)#
hw-module beacon off switch 1
From the actual switch
Switch(config)#hw-module beacon on switch 1
Switch(config)#
*Nov 14 14:10:43.358: %PLATFORM_LED-6-BEACON_LED_TURNED: Switch 1 Beacon LED turned ON
Switch(config)#hw-module beacon off switch 1
*Nov 14 14:10:52.374: %PLATFORM_LED-6-BEACON_LED_TURNED: Switch 1 Beacon LED turned OFF
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Leo Laohoo
Yes and no.
Natively, no.
However, EEM script can.
