Showing results forĀ
Search instead forĀ
Did you mean:Ā
Integrate CVP with Nuance NDM/OSDM
Yugandhar reddy
HI ,
I am trying to integrate the Nuance dialog Module with CVP.
The approach I am following is
CVP --->(calls) SubdialogInvoke --->(calls) VXML page--->(calls)NDM  controller through vxml sub dialog tag.
Currently call traversing to dialogue module and it is taking the speech and recognizing the name that is being spelt.
after taking the input call hangs up.
I am attaching the logs
          1.NDM nametraceLog,
          2.gateway VXML debug logs,
          3.NDM tomcat logs
          4.VXML that is being called from CVP.
I am unable to figure out where is the call failing,
how to return the value back to  CVP.
Is the above mentioned approach current?  If not please suggest how to integrate NDM with the CVP.
Thanks in advance
Yugandhar.
Paul Zimmerman
Log review for this topic would require you to open a ticket
Cisco DevNet: DevNet Developer Support
