ncclient connection not working on CSRv router
nwekechampion
Level 3
Level 3
Hi guys,
I get the below error when I try to make a connection to my CSRv router.
Traceback (most recent call last):
File "C:\Windows\system32\Netconf_env\Scripts\mdp_home_test\get_interface_list_home.py", line 56, in <module>
netconf_reply = m.get_config(source = 'running', filter = netconf_filter)
File "C:\Windows\system32\Netconf_env\Lib\site-packages\ncclient\manager.py", line 212, in execute
return cls(self._session,
File "C:\Windows\system32\Netconf_env\Lib\site-packages\ncclient\operations\retrieve.py", line 166, in request
return self._request(node)
File "C:\Windows\system32\Netconf_env\Lib\site-packages\ncclient\operations\rpc.py", line 341, in _request
raise self._reply.error
ncclient.operations.rpc.RPCError: {'type': 'protocol', 'tag': 'unknown-element', 'severity': 'error', 'info': '<?xml version="1.0" encoding="UTF-8"?><error-info xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:nc="urn:ietf:params:xml:ns:netconf:base:1.0"><bad-element>filter</bad-element>\n</error-info>\n', 'path': '\n /rpc/get-config\n ', 'message': None}
Here is my code below:
#!/usr/bin/env python
import os
import sys
from ncclient import manager
import xmltodict
import xml.dom.minidom
from pprint import pprint
# Create an XML filter for targeted NETCONF queries
netconf_filter = """ <filter>
      <interfaces xmlns="urn:ietf:params:xml:ns:yang:ietf-interfaces">
        <interface/>
      </interfaces>
    </filter>
# Open a connection to the network device using ncclient
with manager.connect(
        device_params={'name':'csr'},
        host= "192.168.0.124",
        port= 830,
        username= "admin",
        password= "Test123",
        hostkey_verify=False
        ) as m:
    print("Sending a <get-config> operation to the device.\n")
    # Make a NETCONF <get-config> query using the filter
print("Here is the raw XML data returned from the device.\n")
# Print out the raw XML that returned
print(xml.dom.minidom.parseString(netconf_reply.xml).toprettyxml())
print("")
# Parse the returned XML to an Ordered Dictionary
netconf_data = xmltodict.parse(netconf_reply.xml)["rpc-reply"]["data"]
pprint(netconf_data)
interfaces = netconf_data["interfaces"]["interface"]
pprint(interfaces)
for interface in interfaces:
    print("Interface {} enabled status is {}".format(
            interface["name"],
            interface["enabled"]
print("\n")
Marcel Zehnder
Remove the filter tags from your payload and explicit define subtree filtering in the get_config method:
<interface/>
</interfaces>
port= 830,
username= "admin",
) as m:
  netconf_reply = m.get_config(source = 'running', filter=("subtree", netconf_filter)
