IOS XR 9000 Netconf-yang Help
olaf.debree
Hi All,
I thought i would post this here as it did not receive much feed back on he support forum....perhaps the wrong place for an api question
I'm wondering if some one may assist with netconf-yang on IOS-XR version 6, Cisco documentation seems to be very limited here.
<edit-config> and <commit> seem to work well but i am having trouble with basic things like "no <command>".
Example: "no shutdown" for an interface. the "http://cisco.com/ns/yang/Cisco-IOS-XR-ifmgr-cfg"; yang file state that the existence <shutdown> tag will shut the desired interface. So the following XML works fine on an admin up interface.
<edit-config>
    <target>
        <candidate />
    </target>
  <config>
        <interface-configurations xmlns="http://cisco.com/ns/yang/Cisco-IOS-XR-ifmgr-cfg">
            <interface-configuration>
                <active>act</active>
                <interface-name>GigabitEthernet0/0/0/1</interface-name>
                <InterfaceModeNonPhysical>0</InterfaceModeNonPhysical>
                <shutdown/>
            </interface-configuration>
        </interface-configurations>
  </config>
</edit-config>
There seems to be no reference to how to enable "no shut" the interface. I would except the below
<edit-config>
    <target>
        <candidate />
    </target>
  <config>
  </config>
</edit-config>
This is accepted by the router and committed but the interface admin state does not change
Thanks in advance
yawming
We can do the no shutdown operation as follows:
Jan 19, 2016: 19:20:39:287770
NETCONF SEND
<rpc message-id="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<edit-config>
<target><candidate/></target>
<config xmlns:xc="urn:ietf:params:xml:ns:netconf:base:1.0">
<shutdown xc:operation="delete"/>
<interface-name>HundredGigE0/4/0/0</interface-name>
</config>
</edit-config>
</rpc>
corresponding config change:
RP/0/RP0/CPU0:fretta53#show configuration commit changes last 1
Building configuration...
!! IOS XR Configuration version = 6.0.1.14I
interface HundredGigE0/4/0/0
no shutdown
end
yawming
NETCONF SEND
<edit-config>
</config>
</edit-config>
</rpc>
no shutdown
end
Thanks yawchen, this works perfectly!!
Is it actually documented anywhere?
Thanks again
Olaf
Olaf,
You should take a look at YDK to dramatically simplify model-driven automation.  Here are some pointers you may find useful:
https://developer.cisco.com/site/ydk/
NANOG 68 Ok We Got YANG Data Models Now What - YouTube
Plus, there's a community dedicated to the APIs:
YANG Development Kit (YDK)
HTH!
Thank you, i tried it and it actually works, but couldn't guess it anyway.
