07-25-2014 04:20 AM - edited 03-01-2019 02:45 AM
Hi All,
I have a few questions related to RONA configuration settings.
I have read few documents and i found the it should be configure at three places, one in CM then in CVP opsconsole then in Agent desk setting in ICM configuration manager.
Currently in my setup it has configure 20sec in all the three places.
if customer requested to increase the time from 20 to 30 sec, which all places i need to change. it will be in CUCM or CVP or Agent desksettings.
And also can any one explain me below timer and how does it works. ?thanks in advance.
Agent Desktop < CVP Invite Timeout < Cisco Unified Communications Manager CFW
Example: 10 seconds < 12 secs < 20 seconds CFW
Thanks in advance. ![]()
Rgds
Fazil Chida
08-14-2014 06:37 AM
Fazil,
I'm not a DBA, and I've never set up SQL backups before. I don't know from looking at your screenshots whether you're doing it right.
I suggest you review this page:
There are some good guidelines there on UCCE backups.
In addition to your SQL backups, I would make sure that you do backup the Windows registry on your UCCE servers.
-Jameson
08-19-2014 06:56 AM
James,
Thanks, that link really helped me..
