UCS Director - How to use controllers (marshal) on custom tasks?
iGeorgoulas
Hi everyone,
I am trying to use the Controllers on custom tasks (marshal/unmarshal) on UCSD. I want when I select something from a LOV to update the GUI values (hide/unhide fields).
I tried with the beforemarshal to add LOV values on LOV and it works. So, I need some help on updating the values on the form fields (or hide some input fields) when the user selects another option from the LOV.
The only documentary I found was:
Cisco UCS Director Custom Task Getting Started Guide, Release 5.4  - Creating Custom Workflow Tasks [Cisco UCS Director…
UCSD Password Check at Workflow Task Level (Controller after unMarshall)
Can anyone share some scripts or give me some guidance on marshals ?
Geevarghese Cheria
Hi Loannis,
  You can try this url - https://developer.cisco.com/site/ucs-director/documentation/latest/index.gsp
Also request to post any further questions related to the subject under UCS Director community so that more UCSD experts can see your question over there.
Thanks and Regards,
Geevarghese
