9800 Wireless Sandbox not found
carlocon
Hi team,
On the past weeks I was exploring WLC 9800 on devnet Sandbox, however lately I noticed when I try to access it that I receive the message "sandbox not found" , thought it was retired, however entering on devnet for wireless I found yet reference for this lab and also get the message Sandbox not found, could you advise if is still available and how to access to it ?
Carlos
5 Replies 5
Hey there, not a sandbox I use. But the general rule, if it is not in the catalogue, it is temporarily unavailable or possible to has been removed. Can you share links, i can ask the team to check.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Hi  Bigevilbeard,
This link is where I found the 9800 sandbox referenced:
https://developer.cisco.com/search/9800/
The first link on the list is
Catalyst 9800 Wireless LAN Controller
However if you click that link you receive the sandbox not found. However I did save a link for 9800 but don't have password to login (nor instructions as before) this is the link:
https://wlc9800.cisco.com/webui/
Feel free to try them just to see if it's just me or these are really not working
Carlos
Thanks for the links. I spoke with one of the ENG team, the SBX has been moved in the dev area for work.
Hope this helps
Well I guessed so, hope would be soon back on line
Gery Escalier
Hi, sorry for resuming this old topic.
I think that in this case, the Cisco Modeling Labs (CML) is a good option: https://devnetsandbox.cisco.com/RM/Diagram/Index/685f774a-a5d6-4df5-a324-3774217d0e6b?diagramType=Topology
If I understood correctly you can customize your own topoligia.
I am needing an AP controller that is in a LAN connected to a router, a switch and one or more APs.
I'll comment as soon as I test.
Greetings!
