Hi team,
On the past weeks I was exploring WLC 9800 on devnet Sandbox, however lately I noticed when I try to access it that I receive the message "sandbox not found" , thought it was retired, however entering on devnet for wireless I found yet reference for this lab and also get the message Sandbox not found, could you advise if is still available and how to access to it ?
Carlos
Hey there, not a sandbox I use. But the general rule, if it is not in the catalogue, it is temporarily unavailable or possible to has been removed. Can you share links, i can ask the team to check.
Hope this helps.
Hi Bigevilbeard,
This link is where I found the 9800 sandbox referenced:
https://developer.cisco.com/search/9800/
The first link on the list is
Catalyst 9800 Wireless LAN Controller
However if you click that link you receive the sandbox not found. However I did save a link for 9800 but don't have password to login (nor instructions as before) this is the link:
https://wlc9800.cisco.com/webui/
Feel free to try them just to see if it's just me or these are really not working
Carlos
Thanks for the links. I spoke with one of the ENG team, the SBX has been moved in the dev area for work.
Hope this helps
