Anyconnect connection problem: No assigned address
athienem
I created myself a collaboration endpoint sandbox, but are unable to get the VPN session running.
The endpoint I tried is devnetsandbox-emea-gwy.cisco.com:20206 but all I am getting is the following message from AnyConnect:
    13:40:01    The secure gateway has rejected the connection attempt.  A new connection attempt to the same or another secure gateway is needed, which requires re-authentication.
The following message was received from the secure gateway: No assigned address
    13:40:01    AnyConnect was not able to establish a connection to the specified secure gateway. Please try connecting again.
Any suggestion what might be going on?
Cheers,
 Andreas
athienem
And an hour later stuff works magically. Thanks whoever fixed it.
That happens sometimes!
