10-09-2023 06:08 AM
I configured the below basic MPLS core network on CML but when I try to enable MPLS on the interfaces within the MPLS core it is not being enabled. When I do a "sh mpls interface" or "sh mpls ldp neighbors" I don't get any output.
R1 hostname R1 int lo0 ip add 1.1.1.1 255.255.255.255 ip ospf 1 area 0 int f0/0 ip add 10.0.0.1 255.255.255.0 no shut ip ospf 1 area 0 R2 hostname R2 int lo0 ip add 2.2.2.2 255.255.255.255 ip ospf 1 are 0 int f0/0 ip add 10.0.0.2 255.255.255.0 no shut ip ospf 1 area 0 int f0/1 ip add 10.0.1.2 255.255.255.0 no shut ip ospf 1 area 0 R3 hostname R3 int lo0 ip add 3.3.3.3 255.255.255.255 ip ospf 1 are 0 int f0/0 ip add 10.0.1.3 255.255.255.0 no shut ip ospf 1 area 0
I tried the below 2 options to configure LDP on the interfaces.
R1 router ospf 1 mpls ldp autoconfig R2 router ospf 1 mpls ldp autoconfig R3 router ospf 1 mpls ldp autoconfig
Solved! Go to Solution.
10-09-2023 06:48 AM - edited 10-09-2023 07:04 AM
Hello @prinsloo007
take care on GNS3, sometimes due to commands, OSPF process is "shutdown".
All you config is pretty good. Do no shut on OSPF process if necesary.
Check OSPF adjencies on all Routers:
After that it should be good!
Note: add command #ip cef command on each Routers
10-09-2023 06:43 AM - edited 10-09-2023 06:47 AM
what IOS image you using for router ?
show version - post here the output
1. are you able to ping p2p interface between routers
2. post show ip interface brief (see interface up )
( some device you need to disable ip cef on IOL Routers)
other side you need to enable ip cef (the one supported) also try global command - mpls label protocol ldp
3. Do you have ospf peering working , show ip ospf neigh
=====️ Preenayamo Vasudevam ️=====
Hello @prinsloo007
08-02-2024 08:48 PM - edited 08-02-2024 08:49 PM
I feel like buying CML is useless. will never reckon to anyone at least if you can't practice MPLS, it is a useless product.
08-03-2024 04:53 AM
there is free GNS3 you can use
for CML it so useful for L2 and security
MHM
08-03-2024 06:58 AM
@AselaPerera9446 far as I am aware MPLS is supported on CML, unsure if this was an issue for the user on the sandbox version back when this posted https://developer.cisco.com/docs/modeling-labs/ios-xrv-9000/#features-tested-with-cml
08-03-2024 07:43 AM
CML is far from useless and I have successfully configured MPLS on it many times. It is vital to identify the proper virtual node type to deploy for your particular use-case, as each node type has trade-offs between supported features and resource footprint (RAM, CPU) requirements, and no node type supports every feature.
