Cisco Modeling Lab Personal Licence?
Chrisyo41
i am learning to get my Cisco Certified Technician Certification  and possibly the CCNA soon thereafter. I have been using Cisco Modeling lab to learn and I have been using the VPN connection to access the website lab. I want to know if I buy the Cisco Modeling lab Personal license what does that come with? Will i no longer need the VPN connection, can I or will my labs that I created be saved after I log off?
any insight will be helpfully.
thanks in advance
balaji.bandi
yes its Local version you can do what ever you want and when ever you want all saved for your Local Lab
cost you around $200 ( and you get 20 devices)
https://www.cisco.com/c/en/us/products/cloud-systems-management/modeling-labs/index.html#~cisco-modeling-labs
check the device requirement : ( dont go with 8GB Ram that is basic, you may need 32 GB ram for good lab to work)
https://developer.cisco.com/docs/modeling-labs/#!system-requirements
BB
balaji.bandi
BB
Thanks!!! That was amazing helpful.
